What are the limitations to the bravo 3? >
Old 11-24-2004 | 04:47 PM
Default Re: What are the limitations to the bravo 3?
Which prop did you calculate the slippage on? They are diff. pitch aren't they??
cooltoys61 is offline
Old 11-25-2004 | 12:21 AM
Just a curious question ,do both shafts spin the same speed.
HARRISONMIRAGE is offline
Old 11-25-2004 | 11:59 AM
Why did anyone ever put a Bravo 3 on a 20' Cigarette??!? Completely inappropriate.
A Bravo 1 is a far obviously better choice with a nice Mirage Plus prop for a try.
Pismo10 is offline
Old 11-25-2004 | 08:14 PM
rslick's Avatar
Exactly what I was thinking!!!!
rslick is offline
Old 11-25-2004 | 08:41 PM
Official OSO boat whore
Yes, they do. As to the staggard pitch, I really don't know. It's not unheard of though. When the pitches are staggered, then you average the two. As to a V-bottom having 6% slip, that's not really feasible with your performance numbers. Something is in error there.
Cord is offline
Old 11-25-2004 | 09:30 PM
formula31's Avatar
Originally Posted by jt29olhp500s
The lower gearcases of the B1 and B3 are
very similar.
Huh? I think you meant the uppers are similar. The lowers are completely different.
formula31 is offline
Old 11-26-2004 | 11:04 AM
SeaRay Jim's Avatar
I think VP Duoprop uses a diferent pitch but BIII does not.
I also agree, something isn't right with the prop slip. Although my boat isn't near the same as a 20' Cig hull, mines more like a 24' bath tub, I have labbed and cupped 26p props. According to Winprop mine has about 11-12% slip. Adding cup and labbing made a big difference. BIII props are notorious for being very imbalanced. Mine was much smoother, and of course bit the water quicker making it more responsive.
The amount of cup added was about the equivalant of a 27p. I think generaly with a BIII, labbing will gain aout 200-300 RPM then you add a little cup to bring it back down and you have 2-4 MPH gain plus it's a whole lot smoother! The motor and drive MUST love that!
SeaRay Jim is offline
Old 11-26-2004 | 11:20 AM
I'm speaking of the overall shape........as far as a hydrodynamic comparison.
JaayTeee is offline
Old 11-27-2004 | 09:19 AM
Live Wire II's Avatar
the B3 has far less prop slip than the B1, so your mid range numbers would much better.
Better fuel economy, lower rpm/mph. You may loose some top end, but to me I would rather have better mid range numbers.
The front prop is larger in diameter than the rear, but the same pitch, The Volvo has different pitches.
Live Wire II is offline
Old 11-27-2004 | 10:54 AM
Unless you have a HEEEAVY 20 footer I still think you'd be more efficient running a B1 with a 4 or 5 blade for midrange and takeoff and not hurt your top speed with the B3.
Swamplizard
15
12-30-2008 08:54 AM
BIGZXXL
3
02-08-2008 07:49 PM
Elite Marine
27
03-11-2006 07:34 AM
Daddio
8
10-24-2004 12:39 PM
