Rhoads hyd. lifters >
Rhoads hyd. lifters
Rhoads hyd. lifters
Old 12-08-2004 | 11:39 AM
robyw1's Avatar
Default Re: Rhoads hyd. lifters
Originally Posted by Edward R. Cozzi
I seem to remember them causing pressed-in rocker arm studs to pull out once in a while. When we switched back the problem stopped. The noise reminded me of solid lifters.
I don't see how this could be. It is spring pressure & excessive heat that is the most responsible for lifting your press-in studs
Roby
robyw1 is offline
Old 12-10-2004 | 01:26 PM
Wink Re: Rhoads hyd. lifters
Roby
You're probably right. Heads should have screw-in studs anyway.
Edward R. Cozzi is offline
estonian
8
01-14-2008 11:52 AM
lukiepal
4
04-03-2005 09:19 PM
RickR
9
08-20-2003 07:34 AM
paradigm shift
12
08-01-2003 10:30 PM
ASD-6
4
01-10-2003 03:20 PM
