Easy question for winter storage >
Old 12-08-2004 | 08:44 AM
OldSchool's Avatar
Default Easy question for winter storage
Question for you guys. For winter storage, is it better to leave the drives in a "neutral" position (which is where I have them) or all of the way down? Just wondering if it matters.
I know that you aren't supposed to leave the drives up so that the bellows boot isn't in a "bent" position all winter.
Craig
OldSchool is offline
Old 12-08-2004 | 08:49 AM
SeaRay Jim's Avatar
Default Re: Easy question for winter storage
I've always heard, and do, leave it down as far as I can. I do make sure it's up high enough that it for some reason the trailer tires popped, it wouldn't be sitting on the drive.
SeaRay Jim is offline
Old 12-08-2004 | 08:52 AM
make sure the drives are lower enough so water doesn't get trappped in the lower housing.ive always put anti freeze in the cavity.no problem
sonic28 is offline
Old 12-08-2004 | 08:56 AM
Manual that came with my boat said to put the drives (Speedmasters) down to extend the bellows and avoid their taking a set. For what it's worth...
Lmarth is offline
Old 12-08-2004 | 12:40 PM
Dave M's Avatar
Veteran: Navy
I always put my drive to about neutral position. My trailer is high enough where I can move the boat with the drive in that position. That way I don't have to put my battery back in to raise the drive.
Dave M is offline
Old 12-08-2004 | 12:57 PM
BajaRunner's Avatar
I always lower mine all the way. A friend of mine left his up, and it cracked the lower housing.
BajaRunner is offline
Old 12-08-2004 | 12:58 PM
full up,down,left- right can squeeze the grease from the bearings(gimble/cross) and cause rust(set).Boats we store, the drives come off.
Dixie Doug is offline
Old 12-08-2004 | 01:55 PM
Audiofn's Avatar
Charter Member #232
Move to FLorida
Put your best foot forward!
Audiofn is offline
Old 12-08-2004 | 03:58 PM
Mbam's Avatar
Offshoreonly Advertiser
Doug has it right, now is the time to pull the drive. Change the lube, grease the u-joints & fittings to purge any trapped moisture. Don't you want to know now if you need any u-joint or gimbal bearing work (or worse)? Engine alignment should be check annually too.
Minus that, neutral sounds good but anything close to all the way down is OK.
Mbam is offline
Old 12-08-2004 | 06:12 PM
Mentalpause's Avatar
Originally Posted by Audiofn
Move to FLorida
That's the best idea
Mentalpause is offline
