stripping powdercoat? >
Old 02-11-2005 | 11:19 AM
  #41
Brad Zastrow's Avatar
Default Re: stripping powdercoat?
For the anodized parts use E-Z OFF OVEN CLEANER Heavy duty. Go ahead and laugh. Spray on very heavy coats and let it sit for hours. Be advised it will also keep eating the aluminum if you leave it too long. Last year I stripped about 50 parts on my boat. Cheap and easy to do.
Brad Zastrow is offline
Old 02-11-2005 | 04:03 PM
  #42
Cignificant's Avatar
Originally Posted by Pat McPherson
Hey guys,
I too have an Extreme Marine platform that needs to be re-coated or painted...
Can I just sandblast and then paint over what ever does not come off?
In my opinion, it would look bad. The p/c is thick and rubbery, so it would be noticable under the paint.
BTW - I painted mine afterwards. I'll never have another p/c piece of hardware on a boat.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 02-11-2005 | 04:26 PM
  #43
Mr Gadgets's Avatar
Charter Member #601
Wally,
Let me know if I can be of help on that drive.. anytime.
Cig, how long did the EM coating last. I have had mine since 2000 and it worries me that some day I will find in falling off, like my Dana tabs??
I dont realish the idea of having to strip it.. but I aggree.. no more PC for me..
Dick
Mr Gadgets is offline
Old 02-14-2005 | 10:41 AM
  #44
Dick
As some have indicated, as soon as you get a nick that goes down to bare metal it's all over. Corrosion gets underneath and lifts the PC. Mine lasted 2-3 years (I run 50/50 in salt water vs fresh). Now I can simply touch up the paint without worrying about it.
The photo at the top of this page is my boat with some "photoshopping" work. I repainted the SP purple after stripping it.
http://www.xmpinc.com/Scripts/Swim_Platforms.asp
Steve Gresham
'03 Donzi 33ZX
Old 02-16-2005 | 08:55 PM
  #45
jmackin's Avatar
Originally Posted by Cignificant
Last winter I stripped my swim platform (Extreme Marine). I took it to a sandblaster - he just gave it back to me after a few hours. It wouldn't even dent the stuff. I tried Acetone - it wouldn't do anything either. Finally tried the airplane stripper - it was the best. Still wasn't an easy job, but it got done.
As someone else indicated, I think it all depends on the type of powdercoating.
Sandblaster guy called and he got it off, but it wasnt cheap- $350!!! Oh well, what kind of primer/paint should I use? Thinking of going w/ a metalic silver to match my Cig. emblem.
jmackin is offline
Old 02-18-2005 | 11:10 AM
  #46
Use a good zinc chromate primer to prevent corrosion. I used House of Kolors metallic purple paint on mine, but they have a silver.
Steve Gresham
'03 Donzi 33ZX
Old 02-19-2005 | 09:46 AM
  #47
rich allen's Avatar
Well, now you have me confused as well. I have been putting off for two years my winter project of removing my windshield, which was originally painted, and stripping it down, sending to a shop, and getting it powdercoated. The current paint on it starting to look its age, with flaking around the snaps for the mooring cover, from the salt water. Thought powdercoating was the way to go, but many of you are complaining about durability when it gets scratched. Now , I have to re-think this.
rich allen is offline
Old 02-19-2005 | 10:09 AM
  #48
Registered User
IMRON
Nothing better for boat parts. PC has nothing more than a mechanical bond to it's substrate, that's why leaving it rough allows it to hold better. With a paint system, a good epoxy etching primer will chemically bond to the metal substrate as well as be tough enough to resist corrosion creep if you do get a scratch. I top the imron off with AFS Evershield. Virtually impermeable when you're done.
Don't attempt to use Imron at home- you need a booth and a fresh air mask system- I wouldn't trust any respirator. It's full of cyanoacrylates- bad stuff.
Chris Sunkin is offline
Old 02-19-2005 | 10:22 AM
  #49
Registered User
Originally Posted by StrikinLightnin
I think as stated earlier that there must be different powdercotings out there.
I tried the gasket remover spray and no-luck.
Sandblasted and it started to throw sparks when held in one spot
still without removing the coating.
Oh boy
There's alot of mystery that surrounds powdercoat- it's actually a pretty basic process. It really isn't anything more than very finely ground plastic that's blown onto an electrically charged part, then melted to flow out and have the particles adhere to each other and the substrate. There are different combinations and formulations of chemicals (plastics & other additives) that go into the process. None of the plastics used have much resistance to methylene chloride, which is the base for most epoxy systems. If it will cut epoxy, it will cut urethanes and alkyds. Try this-
http://www.eldoradochem.com/methylen...-strippers.htm
Old 02-19-2005 | 10:31 AM
  #50
Hang Time 27's Avatar
Don't attempt to use Imron at home- you need a booth and a fresh air mask system- I wouldn't trust any respirator. It's full of cyanoacrylates- bad stuff.[/QUOTE]
Shoot it outside?? For small parts and motors??
Hang Time 27 is offline
