-   -   raise x dimension???? (https://www.offshoreonly.com/forums/general-q/92369-raise-x-dimension.html)
yzbert 12-13-2004 07:35 PM
Re: raise x dimension????
larryd, wow did not relize that 1/4" could make that much diff. does each boat (same make same model) end up with a slightly different optimal x dimension?
all i know is i have a buddy with a newer 36 outlaw higher x 496's runs 4 blades nonlabbed, me 1999 with lower x 500 hps running labbed 3 blades ( cant run 4 blades) and we are pretty close to dead even. i have him by .2-.3 mph on gps ( and that could be a big gust of wind) we run neck and neck. that frustrates me.
baja36ft 12-13-2004 07:36 PM
I am going to try to put the shorties on this week and try it but it's a bit cold out there
so i will see what i can do.want to try them before i pull the motors!!!!!!!!
and larry i didn't mean anything when i said too high!!!!!!!!!!
yzbert 12-13-2004 07:38 PM
i will send you a coat. :D
baja36ft 12-13-2004 07:39 PM
why can't you run 4 blades? i do hydro's 26 pitch with hp500's at 74.8 gps
Sean H 12-13-2004 07:42 PM
i would go 5 blades w/ the raised x and then test, test, test.....
yzbert 12-13-2004 07:46 PM
could not turn them, the threes just worked better. are you running salt? efi or carb?
baja36ft 12-13-2004 07:48 PM
salt water and yes carb!!!
LarryD 12-13-2004 07:49 PM
yes each hull can be slightly different , but if the didn't change the bottom between yours and your buddy's they should be real close so you are right you should be very close to his x boat manufactures tend to be real conservative in thier x dimensions so you can definately go higher then they do and you can always space them back down , thy fact that you are using 3 blades does lead me to think your drives are too deep , unfortunately you just have try it good luck if you get them up you may not be able to get on plane with 3 blades
JaayTeee 12-14-2004 05:50 PM
yz, how fast are you running now ?
I'm going to assume low 70's.
I have heard from more than 1 person
that the 496ho's ( performance wise)
run pretty close to the carbed Hp500's.
I don't know if that makes you feel any better though :rolleyes:
Even though I love to spend other peoples money,
baja 36ft has offered to be the "guinea pig",
his results should be very compareable to what
you should see.
jt
yzbert 12-14-2004 07:47 PM
i run right at 70, last year the gods must have been right and i ran 73 once. make that 69.9 not 70. I would love 74.8. heck i would take 73 again. i hope that baja 36ft sees an improvement.
