Transom Pick up ? >
Transom Pick up ?
Transom Pick up ?
Old 12-21-2004 | 05:44 PM
Sammy
Default Transom Pick up ?
I am putting together a parts list so I can add a fresh water pump & strainer for cooling. I was wondering if anyone can give me any advise on a transom pick up.
THX
Sam
Old 12-21-2004 | 09:30 PM
Smitty's Avatar
Default Re: Transom Pick up ?
I'm with Too Old on this. I run the same one on my rig. It flows very very well.
Smitty is offline
Old 12-22-2004 | 07:22 AM
Official OSO boat whore
I like a pickup that has an adjustable cutting edge. That way you can dial in the exact amount of water pressure that you need. If you have too much pressure, you can raise the edge so you can have less drag. If you are picking up airerated water, you can drop it in deeper. With Freds design, you are fixed. You need to install it too deep to make sure the pickup will work. How about it Fred? Interested in producing a pickup with a adjustable cutting edge? It's not hard to do. A second tube installed inside of the outter one with a lock nut on the inside and a allen screw to tighten it. A sharpened cutting edge to scrape off the water will reduce the resistance. Currently I have mine set to 3/32" below the hull.
Cord is offline
VegasHallett
9
04-30-2008 08:30 AM
jbrauer
05-16-2005 08:38 AM
blown formula
3
10-13-2004 11:47 AM
Skaterfast
Skater
2
09-12-2003 10:35 PM
Cattitude
Eliminator
7
03-21-2002 03:45 PM
