-   -   drive locks off if no key? (https://www.offshoreonly.com/forums/general-q/93050-drive-locks-off-if-no-key.html)
customryder 12-23-2004 02:24 PM
anyone know a trick to get drive locks off with out the key? can you get keys? I bought a use boat without the keys. :eek: Thanks Jeff
mrv8outboard 12-23-2004 03:06 PM
Re: drive locks off if no key?
check with you local marine shop. they should be able to get new keys. i have gotten them before for customers.
US1 Fountain 12-23-2004 03:30 PM
I've used a dremel with a cut off wheel and cut the casing in half on McGards locks before. Then just a pair of pliers to undo the nut.
cuda 12-23-2004 06:31 PM
I've gotten them off with a GOOD small pipe wrench.
ratman 12-24-2004 02:57 AM
use only a little explosive.. or just cut it in half with a cutoff wheel. note it will be quicker and a lot more fun using an explosive charge. please vidoe the eplosion for a how to video for other members or america's funniest home videos. ratman
marinetrans 12-24-2004 07:07 AM
Snap-On 7/16 12pt 3/8 drive deep socket.Use a hammer and drive it in there.Works like the original key.Have to use Snap-On,everything else splits.
cuda 12-24-2004 09:23 AM
I hadn't tried it, but I was thinking along the same lines as Marinetrans. I'd use a cheap impact socket though.
scottc 12-24-2004 09:39 AM
air chisel, catch the edge and vibrate it around to loosen it up. I do that on striped nuts also
obnoxus 12-24-2004 10:48 AM
Or, a 3/8 12pt socket will pull the stud and lock outf. Then just put back and you still have the " lock "
JIMG 12-24-2004 12:02 PM
If you have a key from any other mcgard lock, just put it in a socket on an extension, rap it good with a hammer, put the ratchet on without disturbing it, & spin it off. Works every time.
US1 Fountain 12-24-2004 01:04 PM
Damn, you guys are giving all the theives ideas on how to steal my drives. :cool:
HyperBaja 12-24-2004 01:41 PM
A month ago everyone agreed that drives are impossible to get off unless you have the key.
ratman 12-24-2004 03:32 PM
the locks are only to slow the bad guys down... hopefully they make enough noise trying to steal them or attract attention in the process. the locks i have and have seen aren't deep enough for the socket trick to work most likely. this has been used on wheel lug nuts for ever but you can get a lot of bite because the socket goes so deep on the lug nut. be very careful trying any kind of air chisel as they easily can get away from you and damage other things. drape an old sheet around the area to catch the ground metal bits and use a dremel cut off wheel if you don't have access to a decent compressor and a high speed cut off wheel. should take more than 5 or 10 mins aside. just grind off the head of the thru lock bolt on the back side. be sure to was the boat and rinse well so none of the small bits of metal don't spot rust themselves to the surfaces of the boat. just my .02, ratman
Island Hopper 12-28-2004 05:05 AM
If they are McGuards, a chisel used straight in from the rear, will split the outside ring. Then you can use visegrips to get the brass nut. If you still have the original paperwork that came with them, there is a number, and McGuard can send you another key. If not, the chisel works fine.
