Speedmaster III prop options???? >
Old 12-27-2004 | 03:45 PM
Default Speedmaster III prop options????
I need help finding a prop for my '86 Schiada 22' Daycruiser. It has a blown BBC with a powerglide and early Speedmaster III (19 spline). Currently it has a 3 blade RH chopper that I've cracked both times I've had it out. Not sure of the pitch or size as the markings are nearly worn off.
I need some options!
-Does anyone know of any props for sale for this drive?
-I've read about hub conversions to allow use of outboard props. Anyone with experience with one?
-Any other options short of a Bravo I conversion?
mondorally is offline
Old 12-27-2004 | 03:59 PM
joe900sc's Avatar
Default Re: Speedmaster III prop options????
I have 19 spline SSMIII props but I must sell them in pairs...
If you're interested PM me
joe900sc is offline
Old 12-27-2004 | 04:39 PM
throttleup's Avatar
Try calling Randy or Beth at Cobra Power.
305-893-5018.
Julie
throttleup is offline
Old 12-27-2004 | 04:40 PM
KNOT-RIGHT's Avatar
Im interested if 4 blade 19 spline 30 pitch.
Gerry
KNOT-RIGHT is offline
Old 12-27-2004 | 08:38 PM
Mbam's Avatar
Offshoreonly Advertiser
Randy has a good selection, we also have a nice assortment. Need to have an idea as to what you have now, minus that how about the drive ratio, boat speed and max RPM?
Mbam is offline
Old 12-28-2004 | 07:29 AM
Doller Offshore
your local prop shop should be able to tell you pitch etc.we have a large selection of used props in stock,give us a call @ 954-237-0332
Old 12-28-2004 | 07:37 AM
bob
Charter Member #40
I have a 18 x 30 RH three blade small shaft if interested. Bob 609-923-0631
bob is offline
Old 12-28-2004 | 11:37 AM
I currently don't know the drive ratio. Currently the boat goes approx. 80mph at 5,000rpm. It is a relatively heavy (4,000 lbs) semi-V bottom.
http://schiada.com/Pages/Boats22.html
Thanks for the help!
Justin
Old 12-28-2004 | 11:39 AM
tcelano's Avatar
I was able to purchase a pristine 16.75"x29.5" 4-blade for my SSM III from Doller Offshore for $800. They seem to have a few lying around.
tcelano is offline
Old 12-30-2004 | 01:52 PM
I've got a pair of 15.75 x 26 three blades long hub with 19 spline. They are near perfect and have never been thinned.
CignificantOther is offline
