Oil Line routing? >
Oil Line routing?
Oil Line routing?
Old 12-29-2004 | 04:30 PM
plumbers crack's Avatar
Talking Oil Line Routing ?
Does anyone have a schematic of the oil lines from the engine through the oil cooler and back to the block?big block?Thanks
plumbers crack is offline
Old 12-31-2004 | 03:40 PM
Re: Oil Line routing?
wow my first non response to a question,Whats up?any body want to help the crack?
Old 12-31-2004 | 04:57 PM
Dave M's Avatar
Veteran: Navy
Default Re: Oil Line routing?
Check out www.mercruiserparts.com They have drawings of all merc engines.
Dave M is offline
Old 12-31-2004 | 05:42 PM
formula31's Avatar
Too many people do this wrong and hurt their engines. I can tell you about Mark 4 1988 454's if thats what you have. There are many differences between models and years.
formula31 is offline
Old 01-01-2005 | 02:25 PM
mopower's Avatar
Toxic FORMULA
Guess nobody wants to be responsible for you burning up your engine .
mopower is offline
Old 01-01-2005 | 03:21 PM
The motors are 509 cu gen 6 just want to make sure this time around.I know some people reverse the lines to the cooler so they can achieve cooler or warmer oil tempratures/ or so ive read any way.There has also been some talk in the forum about pressure relief valves,my adapter bolts up to block with a big center flare adapter dont know if I should change that to a billet adapter?And I dont think I have a relief valve.Any thoughts?
Old 01-02-2005 | 10:51 AM
Thumbs up Re: Oil Line routing?
Thanks,just to recap,center of adapter is return to engine block?I followed my lines from the 502 efi and I plumbed the same way.wanted to make sure oil temp sender was correctly installed in series to obtain correct temp.
Old 01-02-2005 | 11:02 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by plumbers crack
Thanks,just to recap,center of adapter is return to engine block?.......wanted to make sure oil temp sender was correctly installed in series to obtain correct temp.
Yes,
And as far as oil lemp location, that all depends if you want to measure cooled or before cooled temps. You'll get arguments both ways on that. I put a sender in for both options with a switch under the dash to switch between the 2 senders and read on the dash gauge. There is a difference.
US1 Fountain is offline
prostockcat
2
10-06-2008 06:44 AM
DONZI
2
08-15-2008 04:25 PM
2
08-16-2007 06:59 AM
nordic95
8
03-07-2006 03:45 PM
redfountain420s
4
03-01-2005 07:17 AM
