Big Block Suggestions Needed >
Old 01-02-2005 | 11:37 AM
Big Block Billy's Avatar
Default Re: Big Block Suggestions Needed
Felpro makes gaskets to bolt mark4 heads on a gen5 block. I think 17046 is the number maybe 17048 too BBB
Big Block Billy is offline
Old 01-02-2005 | 11:41 AM
Also these motors are mentioned as two bolt blocks, gen5 and newer only come in 4 bolt . They have to be mark4. Use felpro 17040 head gaskets. Am I post hoggin' ?
Old 01-02-2005 | 05:14 PM
tripps's Avatar
Yeah bbb,quit hoggin the board!!! get over to the brezze your buddy tripps
tripps is offline
Old 01-02-2005 | 11:37 PM
Prater's Avatar
Big Block Billy,
Thanks for the info. I dont think your hoggin, I really need the help...
So everyone agrees that the Vortec heads will work on the older block with the special Fel-Pro gasket?
Prater is offline
Old 01-03-2005 | 08:36 AM
Crazyhorse's Avatar
The Merlin heads will also work on MKIV and GENV engines.
The FelPro 17048 head gasket is for a bore size of 4.500, I believe the 17040 is for a bore of up top 4.350, 4.310 for sure.
Crazyhorse is offline
Old 01-03-2005 | 11:45 AM
formula31's Avatar
Originally Posted by Prater
Big Block Billy,
Check into this carefully. I was told that my GM Mark 4 heads would not work properly on a Gen 5 or 6 block no matter what gasket. Im not sure about the other way around. Aftermarket heads on the other hand will fit any of them. I think.
formula31 is offline
Old 01-06-2005 | 05:51 PM
Prater's Avatar
I picked up a complete 454 today from the salvage. they did not gaurantee the lower end but did gaurantee the heads rebuildable. supposedly had a rod knock. the heads were 049 castings. $100 we just had to dig it out of their motor pile inside an old barn. Just drpped it at the machine shop to be checked out...
Prater is offline
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
