Intercooler wanted >
Intercooler wanted
Intercooler wanted
Old 12-29-2004 | 10:34 PM
mo3d's Avatar
Default Intercooler wanted
Looking to purchase an intercooler to work with an M1 application. From what I've been reading the RTech is the way to go but the $ is more than I can swing. Any suggestion where I can find one new or used under $1000.00 ?
mo3d is offline
Old 01-02-2005 | 11:57 AM
Default Re: Intercooler wanted
How much?
e-mail [email protected]
thegreygoose is offline
Old 01-02-2005 | 08:05 PM
GPM
I have a used intercooler,it's for the M4 it is the 504.
GPM is offline
Old 01-02-2005 | 09:02 PM
articfriends's Avatar
watch ebay,they pop up about every 2 months,try to find a aw504,it has more cooling than the 324,Smitty.
Ive seen them go for around 600-700$
articfriends is offline
Old 01-04-2005 | 12:47 PM
mo3d's Avatar
By using the larger intercooler will I lose any boost pressure ? I guess it doesn't matter much since the charge air will be cooler right ?
mo3d is offline
Old 01-04-2005 | 02:04 PM
GPM
Bigger cooler, less restriction, cooler air charge,less HP to turn procharger,run higher boost, more timing, less chance of detination, more HP to the prop, faster boat. The 504 cooler has a 4inch inlet and outlet, not knowing what size outlet is on the blower, you may need a reducer, which is available.
GPM is offline
Old 01-04-2005 | 06:56 PM
mo3d's Avatar
The M1 has a 3" outlet as does the carb enclosure. I assume the reducers will not affect air flow correct ?
mo3d is offline
Old 01-04-2005 | 07:27 PM
GPM
It would be fine from the blower to the cooler, it may pick up the air speed going into the carb enclosure, I would probably run a carb hat, for peak performance.
GPM is offline
Full Force
Wanted
2
09-03-2008 09:17 AM
aviatorg3
Wanted
0
04-21-2008 06:26 PM
wrenchman
2
06-30-2006 02:12 PM
azlineman
03-08-2004 10:00 PM
Elite Marine
0
03-18-2003 08:02 PM
