Re: Bravo water Question
Big block billy do you see much air time ? do you lose water presure ? Im woried about cooking a valve with no water presure I have seen it done
When you guys drill the sides of your drives, do you then reseal or paint the tapped hole before installing the fitting? Seems like the raw Al. will corrode if not treated.
Probaly a good idea silicone on threads good /Had weird deal teflon tape on fuel fitings ended in needel and seat causeing leaky fuel bowl who would of thunk it . Motor guy sais always use silicone..
My fittings and hose are SS. Did not not paint and use never seize. I do have to take the fitting out once in a while to remove the pieces of wood. River boating is so much fun.
Salt is very diferent than fresh water on corosion
They used a thread sealant. |
Originally Posted by rbtnt
(Post 1164677)
Or you could take the water out the side of the drive like in this picture. I have seen water run like this and I have also seen just a 90% fitting shooting water up under a top cap like IMCOs.
If you do this, you need to plug the inlet water line in the gimbal. Please don't rag on the dirty drive, It was just winterized and hasn't been cleaned for winter storage yet. Is it ok to still use the drive pickup for the engine cooling? Or do I need a separate pickup? |
Originally Posted by grahamjudith31
(Post 3535985)
I just cut the hose in the transom assy
http://www.cuinsurance.org/7.jpg http://www.cuinsurance.org/2.jpghttp://www.cuinsurance.org/3.jpg |
Then use the drive pickup and don't install a transom mount pickup. If you go with a transom pickup, these are some ideas you can use with the old drive water pickup.
Originally Posted by mr3dman
(Post 3536096)
When moving the water pressure will quickly take care of the "air leak". |
| All times are GMT -5. The time now is 02:06 PM. |
