Engine balancing question >
Old 12-31-2004 | 11:23 AM
Bad Girl's Avatar
Default Engine balancing question
I recently had my rotating assembly balanced in a BBC. I have decided since then to change the rods. do I need to rebalace the entire assembly again for crank counterweight? I changed rods from 6.625 to 6.535 lenght.
Thanks for responses.
Ken
47 Lightning SE
Bad Girl is offline
Old 12-31-2004 | 11:27 AM
vette131's Avatar
Default Re: Engine balancing question
yes
vette131 is offline
Old 12-31-2004 | 11:28 AM
GPM
I hope you changed pistons, they may sit a little low in the cylinder. I would re-balance.
GPM is offline
Old 12-31-2004 | 12:08 PM
robyw1's Avatar
Originally Posted by vette131
yes
What he said ^^^
robyw1 is offline
Old 12-31-2004 | 12:39 PM
formula31's Avatar
Unless by some chance you know the weight of the existing rods and by some miracle the weight of the new rods is the same. And of course that would have to include the new pistons too.
formula31 is offline
Old 12-31-2004 | 12:48 PM
Bad Girl's Avatar
Thanks for the input. I am using the same pistons to get the desired compression. the longer rods were a mistake in what was shipped. should have measured before I started.
47 Lightning SE
Bad Girl is offline
Old 12-31-2004 | 01:32 PM
JCPERF's Avatar
Make sure the crank is cam cut to clear the bottom of the pistons.
JCPERF is offline
Old 12-31-2004 | 08:25 PM
Crazyhorse's Avatar
The shop that did the initial balance work should still have the work sheet with all the component weights. the machinist will just need to weigh and balance the rods, and then balance the crank with the corrected ring/piston/pin/rod/bearing weight.
The short answer is as everyone else has said, yes. Don't cheat now.
Crazyhorse is offline
Old 01-01-2005 | 07:04 PM
Tinkerer's Avatar
I would think that if you can get the new rods to weigh the same as the old rods you should be OK.
I believe that the big end weight has to be the same also.
Tinkerer is offline
Old 01-01-2005 | 07:42 PM
Crazyhorse's Avatar
Tinkerer, are you thinking that you can add weight to a rod to make the 6.535 rod weigh the same as the 6.625 rod did?
