Backfired ..... >
Backfired .....
Backfired .....
Old 01-08-2005 | 07:21 PM
  #51
offthefront's Avatar
Default Re: Backfired .....
Originally Posted by Formula Outlaw
Mike, the Racorp units I'm using are: S 322 OUL Russ
Thank ya sir .. will look into them
offthefront is offline
Old 01-08-2005 | 10:03 PM
  #52
Formula Outlaw's Avatar
Originally Posted by formula31
Do those screw onto the existing fuel filter mounts? ( with the offsets of course)
Yes....
Formula Outlaw is offline
Old 01-08-2005 | 10:31 PM
  #53
'05 Concept SF23
Have you removed your anti siphon valves? They can stick and restrict fuel flow. Are your fuel pumps original? If so you might want to replace the one on the backfire side. However IMHO you probably have crap in your fuel system. Are your fuel bowl levels set correctly? Have you cleaned the fuel filter screen in your carb? Just food for thought. Joe Murray
f311fr1 is offline
Old 01-08-2005 | 10:36 PM
  #54
Lot of times it's the simplest things.
Old 01-09-2005 | 12:14 AM
  #55
Talking Re: Backfired .....
Originally Posted by SeaRay Jim
Here it is lightened up a lot. Pic doesn't look pretty but you can see color on the tips better.
I noticed they are different plugs too. Maybe NGK on the left and Champion on the right??
The best way to check Champion spark plugs is to throw them in the water. If they float then use them...
Edward R. Cozzi is offline
Old 01-09-2005 | 07:36 AM
  #56
Boy if THAT'S not the truth I don't know what is.....I wouldn't use one in my lawn mower, that doesn't run anyway.....
Old 01-09-2005 | 08:44 AM
  #57
Thumbs down Re: Backfired .....
I wouldn't put them in my mother-in-law's car.
Old 01-09-2005 | 08:53 AM
  #58
I would....
Old 01-09-2005 | 09:06 AM
  #59
cuda's Avatar
A few years ago, I had a cruiser. I was running it to the marina I was going to kee it at for the Labor Day weekend. On the way there, I heard a big pop/bang in the engine compartment. I figured I blew the engine, called Seatow and got towed in. Ruined my whole planned out holiday. When I finally got around to finding out what was wrong, I found one of my Champion sparkplugs had the entire center electrode blown out of it. It was even still connected to the plug wire.
cuda is offline
Old 01-09-2005 | 11:06 AM
  #60
Here's my Champion story:
In the late 1960s I had a 1967 427/390hp Corvette. It used the AC 43N spark plugs.
When the plugs had about 4,000 miles on them I would get a breaking up approaching the red line. Nothing I could do would stop it except put in a new set of 43Ns. I was good again until 4,000 miles and the same problem.
I worked for an auto parts chain back then and I told the AC reps about what was happening. They sent a set of my plugs to the lab and the results came back that there was nothing wrong with them. (They looked perfect.)
I tried a comparable set of Champions and they did it in a weeks usage. I never got around to trying Autolites.
