Stainless Marine or Gil Exhaust
wildcard,
I have two sets of Stainless on the new boat I purchased and they leak. The headers are new, but the pipes are not. I took the rope gasget off yesterday to see if its the problem but have no clue. The clamps were tight. Should the rope gasget be completly round? Mine is cut. Do they come this way? Any ideas...enclosed is a pic of were it leaks on all four joints. Leaks very little. Would high temp silcone work?
thanks.
thanks.
He Pismo10,
I have a pair of Stainless Marine exhaust and they work great with my Corsa system. I have had to replace the inside flap on one but this is after 3 years no othr problems..
Good Luck......
Good Luck......
Fred,
Trick sells CMI acessories, and the header exhuast gaskets? Whats the differnce from the
SCE Pro coper header gasket and the High Temp Round header gasket? other that 20.00 price differnce?
H iPerf 2000,
How was the install? any problems, did the brackets fit and work well? Any reworking anything, like trimming that 4" rubber hose or did it just slip on?
Thanks, that is my exact setup in your picture, only one engine tho.
SL
SL
