How do I make this hole bigger?
I need to SLIGHTLY enlarge this hole for my new helm. I have a hole saw of the correct size. How do you keep the drill from walking since there is nothing for the center bit to drill in to? Any ideas?
Originally Posted by Too Old
Attach a board to the back side of the dash covering the hole.
Originally Posted by powerguy
....by using the three holes to thru bolt the board.
Originally Posted by Comanche3Six
Mark the circle with a magic marker, use a die grinder with a sanding cone and buzz it out. Wear eye protection and a mask. Take your time and do a nice job.
Good Luck
Ed
Good Luck
Ed
die grinder, but rest your hand on a solid object and keep the bit deep in the hole so it doesn't get away from you and hack things up.
