TRS - how to tell the difference between Merc and BW trannies?
Going to look at a 1986 Formula 357. Boat has 400 Cyclones and TRS drives. I'm *assuming* that since it has the hi-po motors, it has BW trannies but I want to be able to know that when I look.
Any advice? |
Re: TRS - how to tell the difference between Merc and BW trannies?
The Merc-trans and the flywheel housing are a one piece unit. The B-W trans and flywheel housing are 2 separate pieces.
Starter mounted on top of bell housing, B/W trans. Starter mounted on side of engine,MercTrans.
The velvet drive will loo like the left side of this pic (w/o reduction gear).
http://www.marinegears.com/catalog/cat-bw-dr1.html There should also be a tag on the left side (i think it's on the left) that says velvet drive. Gary |
That Merctrans was basically a Ford C-6 modified for marine use. Years ago when Ford and Mercruiser were in bed together, that tranny came with the smaller horsepower set-ups. Marc Berman told me years ago that they didn't steal as much horsepower as the BW's and the engine could be closer to the transom.
Ed, that's interesting - never heard that before. Funny how we think of the Merc tranny as the "weak" one in a TRS set-up, but the Ford C-6 is actually a pretty stout unit. Shows the difference in road vs. marine use...
The weak link in the MercTrans is the front pump gear. It tends to split right at the keyway. They are a pretty good unit as long as you don't over power it.
I am suprised that no one ever came up with a fix for that pump gear problem. I had a few of them apart and 25 years ago I did a few C-6s, I never made the connection between the 2.
OSO, ya learn something new every day...
Nope, no delay that I ever felt.
| All times are GMT -5. The time now is 07:40 PM. |
