Trim Tabs Stuck To Transome >
Old 01-06-2005 | 04:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Trim Tabs Stuck To Transome
West Marine sells the 5200 remover, Anti-bond. I used it before with success on my exhaust trim rings. If you can get a putty knife started in the joint, spray some of the Anti-bond in there and let it soak. It softens the 5200. Work a little bit at a time.
US1 Fountain is offline
Old 01-06-2005 | 06:46 PM
Steve_H
DeBond 2000® Marine Formula
http://www.debond2000.com/marineform...ove%205200.htm
never used it myself
Old 01-06-2005 | 11:40 PM
Bob,
Goof Off works which you can buy at your local Lowes, Wal-Mart. It works better then what West Marine sells to remove it and doesn't hurt your gel coat.
Your best bet as mentioned above is to work be hind it with a putty knife or wedge of some sort and get as much of the Goof Off behind as you can. Leave it set for about 5 or 10 min and start working it off.
Good luck
Active Mike is offline
Old 01-07-2005 | 01:16 PM
Charter Member # 1083
Thanks for all the replies. Looks like I have a couple of options now.
If it's not a thunder run.............than you're just burnen fuel!!!
BOB ONEIL is offline
Old 01-07-2005 | 09:33 PM
bryanspeedracer's Avatar
The stuff from West Marine does work. I also used piano wire to "saw" back and forth through the stuff. I came up with the piano wire idea after I pulled some of the gel off with the first tab I removed. Take your time. It is the most challenging part of stripping the transom.
bryanspeedracer is offline
Old 01-10-2005 | 01:34 PM
what are you using for paint?
88 MACH 1 is offline
Old 01-10-2005 | 09:38 PM
'05 Concept SF23
test
f311fr1 is offline
Old 01-10-2005 | 10:25 PM
Ginger or Mary Ann?
Hey Mr. Oneil,
if any of the gel comes off, howz about we go ahead and pull that transom assembly off, water pickups and those Mercthadone thingys off also. Clean that puppy up.
Lets DO IT! I have come-along!
Old 05-06-2005 | 12:18 PM
just wanted to bring this ttt and say for you guys approaching 5200...it's all about heat, heat, heat!
Ran a propane torch around on the flange of my stock thru-hulls for 5+ minutes or so, then with a thin angled edged 1.5" putty knife tapped in with a light hammer around under the flange. Then heated up again for good measure...and BINGO slid out like butta...
NO gelcoat damage. I have some to clean up off the gel, but will be careful, and use the heat GUN for that.
I bought the 5015 at West...It appears to me to be BS.
It's all about HEAT.
Rippem is offline
Old 05-06-2005 | 01:48 PM
piano wire works //saw it off
boatnt is offline
