I need a new carb!!!! >
Old 01-07-2005 | 10:41 AM
squick's Avatar
Default Re: I need a new carb!!!!
captchuckv - you've got email
squick is offline
Old 01-07-2005 | 11:33 AM
squick's Avatar
Originally Posted by formulaz583
If you use the adapter, you will lose some carb efficency. Its not a recomended practice for a hi po motor to do this. Get the correct intake for the carb.
The Edelbrock air gap is only $230 and less than $200 for the performer.
squick is offline
Old 01-07-2005 | 11:36 AM
squick's Avatar
http://secure.offshoreonly.com/geocl...php?a=2&b=3156
There's your carb
squick is offline
Old 01-07-2005 | 05:00 PM
mcollinstn's Avatar
STOP chasing your tail.
There is nothing "in" your carb that can cause a rust buildup in it.
You've got crap in your fuel system and it is finding its way into your carb.
Feel free to disbelieve this and feel free to spend thousands of dollars in your attempt to get rid of your "bad" carb, but if you put a $1000 custom calibrated carb on your motor, you'll still end up with it "filled with rust".
My guess?
It's not rust. It's typical fuel system sludge. Dirt. Varnish. Byproducts in suspension. And when the fuel evaporates out of your float bowls (which happens after a few days of non-use) the sludge particles harden into a reddish brown bunch of crap (which does look a lot like rust).
Alternately, you have a bunch of water in your fuel system and it is picking up some iron from your fuel system and it actually IS rust in your carb, but it is coming from upstream and ending up there.
You gotta figure out what you've got in your tanks, separators, and fuel lines.
Cause it sure ain't fresh clean gas.
And a 454 Mag will run as good with a stock 750 Rochester as it will with any Holley or Demon you choose to replace it with (assuming that a carb replacement is your only planned modification).
Stop being hard headed and find the source of your main problem.
mcollinstn is offline
Old 01-07-2005 | 09:56 PM
Payton's Avatar
Charter Member #927
Originally Posted by 2quick
If I'm not mistaken, the '94 motor will have the small peanut port heads. If you're interested, I've got a pretty fresh set of vortec oval port heads that I'll sell you cheap.
As far as carbs, I went with the Sea Demon 750 on mine.
You do NOT have the peanut port heads if you have a 454Mag. You've got a good GM 088 rectangle port head.
mcollinstn, good advise!!
Payton is offline
Old 01-10-2005 | 11:29 PM
AIRTIME
thats a non CG aproved carb no no !
tssteph
Wanted
2
07-31-2008 08:14 AM
horsepower452
3
06-09-2007 06:54 AM
East Coast B
4
07-08-2005 03:57 PM
Dean Ferry
05-15-2002 02:00 PM
