Too Lean?
Old 01-08-2005 | 11:34 AM
CAPTAIN CHUCK's Avatar
Default Too Lean?
Is There Any Easy Way To Check For Leaness? How Do You Go About It?
CAPTAIN CHUCK is offline
Old 01-08-2005 | 11:44 AM
mcollinstn's Avatar
Default Re: Too Lean?
A PROPER plug read,
Determining whether you have a WOT fuel pressure drop off.
Listening by ear as you manipulate the sticks under power, and feeling for the "softening" of the motor.
mcollinstn is offline
Old 01-09-2005 | 08:26 AM
novaII26
Is reading the plugs considered as accurate as an o2 sensor reading on a dyno? I ask because I just built a 540 and on the last dyno run, at 3700-3800 the 02 sensor was at 15.1 which is scary to me, but we read #6 plug, after a fresh instal, and it was a nice tan. should I trust the plug or the o2 sensor?
Old 01-10-2005 | 12:50 AM
I would think you should take more plug readings than just #6 if you are concerned about the accuracy of the O2 sensor. #2 and #7 are generally the leanest.
Griff is offline
gofastlvr
7
08-25-2006 06:26 AM
Strip Poker 388
8
02-25-2005 10:23 AM
lucky strike
Cigarette
21
07-16-2004 02:45 PM
BAD-HABIT
14
05-29-2004 08:31 PM
BAD-HABIT
19
04-23-2003 04:21 PM
