Q-jet Jetting
Over the last few years I have pumped up my stock 330 hp 454's to about 425 hp. Cleaned up the heads and increased flow , changed the cam shaft , went 30 over on the bore , new pistions and bearing , rings and related hardware also put on aluminum intakes ( torker 2.0). My question is about carb jetting. I had the stock Q-jet carbs fattened up for fear of running lean but I think they over jetted. Does any body know what the stock jet setup primary and secondary is so I can base line the carbs . Thanks in advance.
Rick G.
Rick G.
