Added Subwoofer - EASY >
Old 03-03-2002 | 07:27 AM
Default Subwoofer
Raypanic, you didn't mention adding an electronic crossover to your system. Adding an electronic crossover helps considerably. If you only have a bandpass filter in the sub and feed the rest of the system full range you have some real room to improve your system even more with minimal investmet.
Technically speaking, an electronic crossover gives 3 db effeciency gain over passive ( coil and capacitor ) crossover and even more over a simple single bandpass filter system.
To gain that 3 db you have to double your power. To gain another 3 db, double again. That puts the efficiency of the electronic crossover into perspective. It effectively represents doubling your power or maybe more in your case.
Also, if you have any way to physically couple your sub to the boat, it should improve low frequency output.
Bolt (not screw !) your sub in with heavy rubber washers between the sub cabinet and the boat.
Good luck and good listening.
deboatmon is offline
Old 03-03-2002 | 08:02 AM
INDY27's Avatar
Lightbulb
guys check out WWW.UBID.COM they have new and refurb gear for pennies on the dollar! I have seen new bazooka subs selling for well under $100.
INDY27 is offline
Dono77056
Pantera
2
04-27-2008 10:01 AM
rockstar38
Cigarette
21
03-21-2008 03:52 PM
Pantera24
Pantera
11
03-10-2003 10:35 PM
