-   -   Volvo Diesel's (https://www.offshoreonly.com/forums/general-q/94410-volvo-diesels.html)
AA/FuelCoupe 01-13-2005 09:38 AM
Volvo Diesel's
I'm repowering a 26'Formula does any one know about the 160hp diesel Penta drive package.
I was at the boat show in NY the guy says these are better the the Merc deal.Any one ever seen these 5cyl. turbo engines?
How does the 160 out power 220hp v-8's.
Stormrider 01-13-2005 10:44 AM
Re: Volvo Diesel's
I'm not sure how much room you have, but check out these.
http://www.marinedieselusa.com/
Poorsche 01-14-2005 01:29 AM
Re: Volvo Diesel's
Have you seen any pricing--retail/street/wholesale?
How do prices compare to Yanmar -- if you know--
THanks
Poorsche
JIMG 01-14-2005 01:09 PM
Re: Volvo Diesel's
I am guessing at that horsepower you are talking about twins. The way that is figured is that you can only use about 70% of your hp at cruise with a gas engine. When you run a diesel the figure is at about 90% or better. When you figure it out this way you need about 170hp diesel to do about the same job. If when you are doing this you switch to duoprop drives, the cruise is even better enhanced. Where are you from? I may be able to give you pricing. (depends on your location). The horsepower should hold up very well against any of the competitors. These engines are full electronic control and super efficient.
AA/FuelCoupe 01-14-2005 02:55 PM
Re: Volvo Diesel's
JIMG
I'm from Long Island the shop doing the job is in SCarolina.
C_Spray 01-14-2005 03:14 PM
Re: Volvo Diesel's
2 Attachment(s)
You might look into using a single D6/350 or D6/310 DPR setup. They are all digital controls, so rigging is simple. Weighs slightly more than a single big-block setup, but is just a little longer. There are two different drives, depending on how fast you expect to go:
AA/FuelCoupe 01-14-2005 04:20 PM
Re: Volvo Diesel's
CSPRAY
I can't access those images,not platinum member.
Thanks anyway
JIMG 01-14-2005 04:33 PM
Re: Volvo Diesel's
You didn't say if it was twins or single. If twins the D3-160 dp would do the job nicely, if single the D6-310 or 350 dpr would be great.
AA/FuelCoupe 01-14-2005 06:39 PM
Re: Volvo Diesel's
JIMG
Twin's, can you help on the price ?
Edward R. Cozzi 01-14-2005 07:16 PM
Re: Volvo Diesel's
Just a suggestion, but typically 5 cylinder diesels have had vibration problems in the past. Maybe now they're okay.
I would experience these engines in someone else's boat before I bought them.
