Value of 454 Mag Gev V take out >
Old 01-18-2005 | 12:52 PM
dyno's Avatar
Charter Member #655
Default Re: Value of 454 Mag Gev V take out
like these
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 01-18-2005 | 01:01 PM
powerguy's Avatar
What kind of warranties to the 496 T/Os come with?
And is merc power what you want?
And why are you repowering? are your blocks tired?
496Ho's have balance of factory warranty. Motors have between 5 and 15 hours.
Not married to Merc power but like reliability and improvements of fuel injected power.
Motors are still runing strong just thinking about more power and speed and looking toward the need for a rebuild in a couple years. Also looking to replace stock exhaust now and don't want to have the expense if the best plan is to go with the 496HO.
"All I need are some tasty waves, a cool buzz and I'm fine"
powerguy is offline
Old 01-18-2005 | 01:47 PM
PatriYacht's Avatar
All things being equal, I like to go for cubic inches. I do see where you're coming from though.
PatriYacht is offline
Old 01-18-2005 | 01:51 PM
Stormrider's Avatar
JC Performance Engines
I ran my engine till she gave up.
I could possibly get a $1000 for the long block.
I did the rebuild becuase I had to.
I was at the NY boat show, someone said to me, "those that usually repower, sell within a year." Basically meaning that the power upgrade will not usually give you the change you are looking for.
Stormrider is offline
Old 01-18-2005 | 02:56 PM
cstraub69@comcast
Sutphen,
It's all about what your own budget it. This application is not asking for extreme power so Eagle/Scat/Probe would be fine for rotating assemblies. Scat's nodular crank will hold 500HP for hours with no problem. With any of these it is important to check all the mating surfaces for tolerance spec.
Personally. If I were building a 500HP engine I would use the Scat Nodular iron. Over the years the nodular iron cranks have proved themselves to me and my customer's to be a good choice for mild builds of 1HP per cubic inch.
The Gen 4, 5 ,6 have thousands of aftermarket choice's available to them. The OSO member has good heads and block so to me it would make sense to build what you have now in the winter months.
Chris
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
wet_rat
09-26-2007 12:01 AM
thanks_don
11-19-2006 08:24 PM
Cmoney
3
08-02-2004 11:15 PM
