Afr 315cnc - 114cc, Cam????????? >
Old 01-18-2005 | 05:38 PM
Default Afr 315cnc - 114cc, Cam?????????
has anyone run the afr 315cnc with 114cc chambers on a GEN VI hp500, or the afr 305's ? what cam did you try ? i've got cmi e-top exhaust. thanks
hpscarab22 is offline
Old 01-18-2005 | 06:13 PM
cstraub69@comcast
Default Re: Afr 315cnc - 114cc, Cam?????????
The AFR's are killer heads that flow alot of air quickly with excelent port velocity so a large cam is not needed for Rick's heads. Something mild in durationa and with moderate lift will give you very good torque numbers and a nice HP peak.
Chris
later
3
08-03-2008 02:00 PM
Fenderjack
26
04-11-2007 09:44 AM
WAGS382
143
03-01-2005 07:56 PM
PatriYacht
23
03-19-2004 06:31 AM
Monty
38
01-06-2004 05:16 PM
