dart intakes >
dart intakes
dart intakes
Old 01-23-2005 | 06:34 AM
Default dart intakes
I bought a set of Merlin intakes for a set of 540,s with gm heads . But to be installed I would have had to machine the ends to fit the heads cause of a knot onthe head. They didnt tell me this at CP Performance when I ordered them . So I used the big brodix APBA style. But it seams My torque curve could move up a bit if I used the Merlins cause the intake plenum is tapered bown smaller then opens back up . I am learning that bigger is not always better. Any opinions ?
boatman747 is offline
Old 01-23-2005 | 08:54 AM
Stormrider's Avatar
JC Performance Engines
Default Re: dart intakes
Bigger is not always better.
I just got a set of Dart Iron Eagles for my 461cu.
The smaller ports should help out midrange alot too.
Stormrider is offline
Old 01-23-2005 | 04:52 PM
Vinny P's Avatar
I hate the winter!!
I recently went through the decision of bigger or smaller intake runners. I just built an NA 540 with AFR 315 cnc'ed heads. I tossed around the rectangular port vs oval port intake for a while. I ended up using a Dart oval port intake, which I gasket matched to my AFR heads. There was alot of material to remove at the exit of the intake runner. I went into the port about 1 1/2" to get a smooth transition. It seemed to work out well for me. I was happy with the dyno results.
Vinny P is offline
Old 01-23-2005 | 06:48 PM
RLW
It seems my torque curve could move up a bit if I used the Merlins cause the intake plenum is tapered down smaller then opens back up .
I am curious to know if there is any truth to the above statement.
Can anyone shed any light on this?
RLW is offline
Old 01-24-2005 | 12:20 AM
RedDog382's Avatar
Boatman,
Sterling used Brodix on my 510 c.i. motors. Also had a friend gain 200-300 rpm over Dart intakes with Brodix on 502's. Should work well for you.
RedDog382 is offline
Steve Snider
Wanted
1
11-11-2008 07:41 PM
Fenderjack
Swap Shop
0
10-18-2008 09:34 AM
shaun harrington
Wanted
1
05-19-2008 11:03 AM
Fenderjack
19
02-21-2008 10:03 AM
carreraboat
29
01-09-2003 04:38 PM
