Dyno near Milwaukee WI
I would say Riggs is your best bet also, he can also dyno your motor while its in the boat if your looking to just get hp numbers. If you want to get egt numbers then I don't think youll be able to dyno the motors with wet exhaust.
As far as some place closer to you, there is also motor masters in hartford, but I'm not sure if he could get to you now since he's swamped with race motors.
I'm building a 502 mag efi and having the programming done By Mark Boos in louisiana but while talking to him on the phone the other day he suggested I have the engine dyno'd to make sure it's safe to run
!!!!! I'm SO close to giving up on the EFI and throwing a carb on it.
Doug
!!!!! I'm SO close to giving up on the EFI and throwing a carb on it.Doug
I called Riggs Marine Services. They can get you a HP number with the engine in the boat, but only HP up to 500. They did say that they know of a Dyno room in FonduLac area starting at 350.00.
Doug
been by marks everyday for the past 2 weeks , he's the man
send it down anrd toss on the dyno , you will be glad you did
