500HP's to 575's??? >
500HP's to 575's???
500HP's to 575's???
Old 01-30-2005 | 12:49 PM
Panther's Avatar
Frank's Marine Service
Default Re: 500HP's to 575's???
600hp should be easy with upgraded heads (Dart, Merlin etc.) and a different cam.
Panther is offline
Panther's Avatar
Originally Posted by Linster
650 HP out of a 502 on pump gas will not happen.
I think it is possible with a set of Aluminum heads and a solid roller cam.
Panther is offline
Old 01-30-2005 | 01:53 PM
NJSONIC's Avatar
Call Innovation Marine in Sarasota Fl. I'm sure they can help you. 941-355-7852
NJSONIC is offline
Old 01-30-2005 | 02:14 PM
Linster's Avatar
Off the Radar
Maybe I did not say well what I was trying to relay.
I have not found any professional marine engine builder or an marine engine builder with a dyno to say they get 650HP out of a 502 that will be used in a boat reliably.
You can get to that number if you spin a Solid Roller cam up way past 6000 rpm. In reality, It will not have any more torque available past 4600-4800 rpm. It probably would make less torque than a good 600 hp motor to achieve a HP number that would be needed to get that 650 hp number. About 5400rpm it will stop pulling in a boat because the peak torque curve is falling off. I would look at the HP around 5400-5600 to be the top usable HP in a boat. Shooting for 5400-5600 rpm will give the largest torque number and will work much better in a boat. Torque is more important than HP, so my suggestion is to work on the peak torque number, then try to keep it from falling off too fast past 4800 rpm.
Scoogin Dickey has a 509 602HP. Alum Heads 10.2 compression using automobile headers.
Teague offers a 509 620HP Version.
These are my thoughts for what they are worth.
Linster is offline
CAPTAIN CHUCK
21
02-14-2008 09:19 PM
Boomer35
03-09-2006 08:00 AM
Gizmo
31
10-29-2004 11:31 PM
scooby1
4
06-12-2004 10:22 PM
Gizmo
1
12-06-2002 07:23 AM
