oops
1 Attachment(s)
crap.
anyone know a better way to get this out besides an easyout aka (never works and always breaks) :( |
Re: oops
I had quiet a few broken stainless bolts in my trim tabs and my old TRS Gimbals.
Try the Craftsman Drill-Out or Micro Drill-Out. They work allot better than standard extractor. The left handed drill portion of the things are very hard and will cut into the stainless VERY well. Make sure you center punch it carefully and take your time drilling. If they break they usually break leaving enough of the extractor sticking out so that you can remove the broken extractor. They don't stay stuck in the bolt like regular easy outs. Good Luck! Dan |
Re: oops
1 Attachment(s)
The set you need is part #52155
Re: oops
thanks a bunch Zanie!
these gotta work better then an easyout. |
Re: oops
I hate to say it but............................
read the instructions. Also, take your time. |
Re: oops
instructions? we dont need no stinky instructions :evilb:
i have access to a bridgeport mill at work so i wont have any trouble getting it centered. |
Re: oops
snap on tools makes the best extractor set you get 5 sizes in the set. there are 5 drill bits, 5 fluted studs, that you drive into the hole you drilled. then slide a hollow nut over the stud the flutes bite into the inside of the bolt and the nut catches hold of the flutes to back the broken bolt out. the great thing is that the stud isn't too hard ( most easy outs break off in the hole because they are too hard). the snap on stuff will give a bit so you can feel whats going on, with out fear of breaking the stud off inside the broken bolt. been there with easy outs. ever try to drill out a broken easy out forget it...
Re: oops
Before using the extractor.
Heat up the busted fastener and dab some parifin wax on it. It will come out effortlessly with the extractor. A candle will work if you have no parifin. |
Re: oops
thanks guys. i went out and bought the craftsmen set today. havent tryed it yet but when i do ill give it some heat and wax.
Re: oops
use the smallest bit possible to get it started, and once you have a pilot hole, open it up a little more, once the center is out the threads can release more with the extracter, not as much tension, a little heat will help as well.
never tried the parafin/wax trick. |
| All times are GMT -5. The time now is 04:21 AM. |
