-   -   TRS gimbal ring help needed... (https://www.offshoreonly.com/forums/general-q/95945-trs-gimbal-ring-help-needed.html)
Ted G 02-06-2005 10:50 AM
2 Attachment(s)
84 TRS gimbal ring with u-bolt at top. Can the ring be removed without pulling the transom assembly??? What is needed to get the top pin out? Do you have to cut the housing like a Bravo???
Pics
open87 02-06-2005 11:48 AM
Re: TRS gimbal ring help needed...
2 Attachment(s)
here is the housing shot , i belive you will have to pull the housing. those nuts will most likely fight you. the top pin nut is a biotch. you also have to remove the tiller arm , etc the ring is probably cracked where the u bolt seats.
Scott B 02-06-2005 11:58 AM
There is a gimble ring kit.. Comes with the new ring, plugs for the holes you have to drill, misc parts and a bellows....
Around 850 bucks..
I have the instructions for it at the office, could scan and email em to ya...
Mbam 02-06-2005 01:56 PM
It's a pain, but it will come out. Same procedure as a Bravo, however the upper steering shaft is usually stuck in the ring. If you are not going to re-use the gimbal ring, cut it on both sides with a sawzall, and deal with the steering shaft in a press.
