who does good gelcoat work in Austin >
Old 02-10-2005 | 06:32 AM
aTX427's Avatar
Default who does good gelcoat work in Austin
Has anyone had good experience with a shop in Austin? I would be willing to go to Houston or DFW if necessary.
aTX427 is offline
Old 02-10-2005 | 07:34 AM
Default Re: who does good gelcoat work in Austin
What do you need to have done? I've heard the shop in Lakeway Custom Boats(?) maybe does good work but since I do my own I can't say first hand. There's also a shop out in Volente but again, I have no first hand experience.
John
JohnJan is offline
Old 02-10-2005 | 08:57 AM
SeaRay Jim's Avatar
Depending on what you need to have done, Full Throttle Marine might be able to do it. Bob's got mine down there now finishing up getting a new motor in and doing a little gel coat work.
SeaRay Jim is offline
Old 02-10-2005 | 09:18 AM
BajaRunner's Avatar
I had a BAD experience with one in Austin. Not any of the above.
BajaRunner is offline
Old 02-10-2005 | 10:33 AM
aTX427's Avatar
I need to have my dash completely resurfaced on my 38.
aTX427 is offline
Old 02-10-2005 | 01:25 PM
Have you considered paint? I can't think of any real advantage gel would have in that application, and the hassle of spaying, sanding,and polishing gel is a huge disadvantage.
JohnJan is offline
Old 02-12-2005 | 07:32 AM
aTX427's Avatar
I do not think paint will work. There are stress cracks that need to be ground out. I know a couple of good shops in Dallas, but they will not have the space for a 38' boat.
aTX427 is offline
Old 02-12-2005 | 10:40 AM
CcanDo's Avatar
you might try SUN VALLEY FIBERGLASS.They are just south of Ft Worth off from I35 about a mile.They have two good sized ex aircraft hangers to work in.The phone number is 817-293-9568.Larry Boyd is the owner and contact.They just did a dash for me along with a lot of other work.All gauge holes were filled,the helm was removed and the total dash was matted,glassed,gel coated black,sanded and polished to mirror finish.I had planned on overlaying with carbon fiber.However,after seeing this I am not.
CcanDo is offline
Old 02-12-2005 | 10:56 AM
Did you have Larry paint it too?
John
Dueclaws is offline
Old 02-12-2005 | 11:08 AM
John, I've heard Custom Fiberglass does good work, but are pretty slow and expensive...what's new right? That's not a job I would personally want to undertake. Are you going to pull all the gauges and such or do you anticipate the shop doing it all? We have a good fiberglass man that could do you a good job in gelcoat or imron, but he doesn't do fancy graphics. What we would probably do is derig the dash and then send him the boat to fix the dash. Give me a shout if you want to talk more.
Bob
bobl is offline
