SSM#3 install on my Donzi Z-33 Help?
So by moving the engines forward 18" (just a guess)... how does that effect speed, etc? Is this a negative or a positive?
Also, I recently bought a 2003 496mag with 2003 Bravo 2 and 2003 transom.... I will probably horsetrade everything for a twin drive set up... if anyone is interested.
Thanks again for all of the help!
You will have to glass up the transom and move everything inside forward and up. If you have the 454 mag set up with a Alpha then you more then likely I would guess have 330hp motors not 365's. They did that for a few years for some odd reason. Personally I would just get a bravo and be done with it. No glass work, it just bolts right up to the old set up with the addition of two holes, and if the alpha lasted all this time then you should be fine with the Bravo's. I guess you have to weigh all the prusses and minus's but I am guessing that it will cost a LOT more then you think to do all that.
Jon
Jon
Put your best foot forward!
Jon
Jon
Originally Posted by monstaaa
hey team i have 2 bravo h.d gimbals, 2 imco x-treme drives, prop's and a kieth eikert external steering system. additionally all we do in our facility is new, and reriggs. we can probably be help to you. call me 516 799 6029
Sounds great... I will call you tomorrow or Monday for more info. In the mean time... can you e-mail me with more info and pictures? [email protected]
Thanks again!
Q
Thanks again!
Q
Thanks again!
Q
Absolutly go with the Bravo's....basically a bolt on affair.......WAY better for resale........ANY merc dealer will have parts and be able to work on it.......doug
