Props off kaama drive same as sm. shaft ssm
I don't know much about Kaama drives soooo, Drives were on 30' Formula, Props are Keikhaefer 6" hub w/ 19 splines.Are these the same props as used on #3 ssm and small shaft 3A and #4? Hate to buy another set of props if taper and dia. wrong. Thanks for the help!
Re: Props off kaama drive same as sm. shaft ssm
NM--
Kaama props are 19spline(small shaft) they are the same as ssm #3, 3a's are different. Kamma's are also 6" hubs on most of them. I own a Kaama 35' Formula and run ssm#6 (large shaft) props with an adapter kit. I am looking for a set of small(or large) 17" x 26p props. There were many Kamma boats that came with the 16.5 x 26 props. Hope this helps. |
The Kaama is the same shaft as the small (Long shaft 6 inch) #3 or #4. Are you running 3 or 4 blade props? When I had Kaama's on a 30 Sutphen I generally ran 4 blade, they planned better and were a little smoother. Three blades had a little better top end.
I have a Kaama manual I can email if you are interested. mike |
1 Attachment(s)
Mine came with the 16.5x26 four blades, also a 30 foot Formula.
Thanks guys I bought the props!
I make the adapter kit that allows you to put a SSM#6 propeller onto a 19 tooth spline shaft.
Early SSM#3, KAAMA, and Arneson ASD6 drives all use the same propeller. 3A and above have the 26 tooth shaft. |
1 Attachment(s)
They Look like this!
Rik Thanks For the Bushings! Job well Done :D Gonna see if I can bring the 32,s up to 5800 rpm. Maybe ill break my record. Now if I can make it through this year without Running over a floating log. :rolleyes: |
| All times are GMT -5. The time now is 10:38 AM. |
