Rocker Ratio 1.7 vs. 1.8 >
Old 02-18-2005 | 11:47 AM
Pat McPherson's Avatar
Default Re: Rocker Ratio 1.7 vs. 1.8
Hi Guys,
I ran the add 0.028" of lift through desk-top-dyno and it would seem like the +8 horsepower is not worth the switch.
How much of a gain is there from going for stamped to roller? 5-10HP?
Yes, I have thought of the ZZ502 cam. But Mark at Precision told me that cam is not a vary good cam for an MPI engines with only 8.7:1 compression...
Also, I have the short captain call risers.
Patrick
Pat McPherson is offline
Old 02-19-2005 | 11:52 AM
rush's Avatar
I would go with rollers either way, there stronger an much more precise
rush is offline
Old 02-20-2005 | 07:08 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
You'll never regret buying a good set of roller rockers (ie. Comp Cams stainless magnum version) if only for the piece of mind. I've broken/cracked most other aluminum body roller or stamped steel versions.
I now rev freely with no worries
martiniboat is offline
Old 02-21-2005 | 01:43 AM
The correct way to figure is take lobe lift times rocker ratio.
Example:
DUR:
248 IN----254 EX @ .050
287 IN----292 EX Ad.
Lift:
.663 IN---.680 EX
Lobe lift :
.390 IN---.400 EX
1.7 ratio .663 IN---.680 EX
1.8 ratio .702 IN---.720 EX
1.9 ratio .741 IN---.760 EX
2.0 ratio .780 IN---.800 EX
All cams are advertised with the lift amount for the rocker ratio the motor had stock. A small block chevy will sometimes have a cam with more lobe lift than a big block cam, but be advertised with less lift because of the factory ratio of 1.5.
Advantages to more rocker ratio is quicker valve movements in the same time frame so valve velocity is increased. The motor thinks it has a more agg. camshaft. The obvious reason is more total valve lift.
If you ever change anything in the valve-train you must figure valve geom. (pushrod length) at the very last. Nothing wrong with running more rocker ratio, but must check V to P clearance and pushrod length.
All cams are figured this way, it's just easier for them to give you the total valve lift for the stock rocker ratio when advertising.
NOBODY is offline
Old 02-21-2005 | 06:58 AM
Good Point!
I had not thought about that one...
Patrick
Old 02-21-2005 | 10:39 AM
Make sure you have enough clearance between the valve and the piston still.........
Pismo10 is offline
imq707s
9
08-11-2013 06:40 PM
rhsj2006
15
08-27-2008 12:02 AM
26scarab
3
06-14-2006 10:45 AM
ratman
12
03-27-2005 10:30 PM
ratman
03-26-2005 10:13 PM
