Best Drive Showers?? >
Old 02-20-2005 | 11:05 PM
Default Re: Best Drive Showers??
Originally Posted by formuladude312
Holy Waterflow!!!
I agree!
Active Mike is offline
Old 02-21-2005 | 02:03 AM
my32dominator's Avatar
Simreks. Put a set of Halos on the Dominator last fall.
my32dominator is offline
Old 02-21-2005 | 06:44 AM
MnFastBoat's Avatar
Charter Member#157
This is what I have on my Cat.
I absolutely love them!
Drives are as black as the day they were made at Merc. NO sign of white residue that you would see from drives getting hot and then cooling down.
I like the sheeting action versusthe hose spray.
Another brand of top shopw just pushes the water over the top, does not push itdown the sides like this unit does.
Check it out and at the same time broaden you knowledge.
http://www.innovativemarine.net/
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 02-21-2005 | 07:20 AM
Slamin
Speaking of drive showers for those running Alpah SS drives what kind of shower are you using.
THX
Sam
Old 02-21-2005 | 11:41 AM
Gizmo's Avatar
Are we having fun, yet?
I had the simrek halos on my last boat and have installed several others. I need to purchase one or two more. Let's get an order together and take advantage of Paul's generosity. I'm in for at least one.
Jay
Gizmo is offline
Old 02-21-2005 | 12:13 PM
Official OSO boat whore
I'm going to second Mn on this. I too have a Innovative marine cap on my cat. Mine is plumbed into the raw water pump. Mfr's can come up with all the fancy gizmo's they want, but if you have a high drive height, a cavitation plate mounted shower just won't work. Oh, and you'll never have a pickup cavitating your prop either.
Cord is offline
Old 02-21-2005 | 03:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Good looking outfit. Has anyone had cavitation that can be 100% verified from the pickup tubes of showers, or just speculation? Otherwise there are alot of boats out there with the steering tabs that hang down a few inches that are in a world of hurt.
US1 Fountain is offline
Old 02-21-2005 | 08:04 PM
Too Old,
I will be in the market for a new shower for my "hole in the water" since I have put this Imco lower on it. What do you recommend for this set up?
Chris
cstraub is offline
Old 02-21-2005 | 08:21 PM
Well let me know and I will throw some of this Stef's Oil Pan money down that way.
Chris
cstraub is offline
Old 02-21-2005 | 08:25 PM
Yes I know for a fact that drive showers can cause cavitation, .
When I bought my boat it had no drive showers on it. Installed a pair of innovative marine showers and immediatly had cavitation problems planing off. Innovative replaced the non adjustable pick up tubes with adjustable ones. I then moved the tube up 1/4 inch which eliminated the problem.
So its been my experience that the height of the tube makes a huge difference in whether or not you have cavitation problems.
RonS is offline
