Imron on gelcoat...what about seems? >
Old 02-22-2005 | 06:30 PM
Default Re: Imron on gelcoat...what about seems?
I would just paint the entire sides white and then do the flames in vinyl. Don't have to clear it then and the graphics can be changed easily.
Griff is offline
Old 02-22-2005 | 06:54 PM
Originally Posted by blue thunder
My experience says Imron is a poor choice in paint in under water applications. It will take on water, bubble then peel off in sheets.
BT
Doesn't Formula use Inron? Not disagreeing with you, but they obviously don't have a problem with it, so is there a diff in painting new gelcoat vs old, or why does it work for Formula?
Chart is offline
Old 02-22-2005 | 07:48 PM
Painting white and then using decals for the flames sounds easier and cheaper, but I want to fade darker blue on the edges, over the slightly lighter blue in the middle. I know it will cost more, but I am going for something like this pic below, without redoing the upper half of the boat.
thanks, j. Sorry to kinda copy someones boat, but it looks awesome!
Attached Thumbnails Imron on gelcoat...what about seems?-1524commander24channel.jpg
justinVIP is offline
Old 02-22-2005 | 08:57 PM
daboatman1
Cool Re: Imron on gelcoat...what about seems?
Check out www.lbgraphics.com They have vinyl with graduated color fading. The web sight is takes a little time to navigate. Lots of info.
Old 02-23-2005 | 08:03 AM
that sight is pretty cool, but way unorganized. Thanks, I got some ideas off of it. You can also order just the cutout so that you can use it as a template.
Old 03-10-2005 | 08:10 AM
vandeano's Avatar
I painted my 27' Carrera with Awlgrip 2000. Awlgrip 2000 is nothing like the original Awlgrip. With 2000 you can paint your boat out doors and go back and color sand and polish out and imperfections (orange peel, dirt, runs...etc). It cost me about $1000 in materials.
The money I saved doing it myself $6000. The graphics I'll do in vinyl. I even saved more money by buying a vinyl cutter on E-bay for $650 and I can cut out my own graphics.
vandeano is offline
Old 03-10-2005 | 08:37 AM
Ted G's Avatar
Rule of thumb for Imron in the water is 3 days then get it out to dry. You can extend to 4-5 once in a while but that's about it. I have a friend that has done this for 4 years with no problems-but yes, it's all in the prep.
www.cbpba.com
Ted G is offline
Old 03-11-2005 | 08:00 AM
jayboat's Avatar
Vinyl can be airbrushed, but it has to prepped correctly. The faded stuff wont allow the type of look I think he is trying for since it is a linear fade and wont contour with the flames. One other option to consider is a digitally printed vinyl wrap. When you're ready to sell the boat, you can strip it and go back to the factory color.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
24degrees
Detailing, Painting, & Fiberglass
2
05-21-2006 10:50 PM
Top Banana
8
09-03-2005 12:12 AM
phughes69
07-08-2004 10:38 AM
LPA2106
02-19-2004 09:53 AM
RLW
22
01-06-2003 07:31 PM
