which muffler to use? >
Old 02-22-2005 | 08:42 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default which muffler to use?
4.5 inch dry exhaust, which muffler would you use?
mcraymond3 is offline
Old 02-22-2005 | 08:55 PM
Default Re: which muffler to use?
Not sure if they make 4.5 or how they would be with dry exhaust but the GGb Extremes if they will fit your application would be my recomendation, I know a couple of guys that i boat with that have them no rpm loss or horsepower loss, I will be puting on a set on formula this year to avoid the noise police.
formuladude312 is offline
Old 02-22-2005 | 09:17 PM
GPM
You can see those mufflers at GGB.CA
GPM is offline
Old 02-22-2005 | 10:02 PM
paradigm shift's Avatar
Worth a look. Has some nice deals on these right now. Not sure they have all sizes available yet.
http://www.gibsonperformance.com/vie...fflerflyer.jpg
paradigm shift is offline
Old 02-22-2005 | 10:11 PM
Attack's Avatar
I've been using GGB inserts. They work great, but they are not quiet enough for our 3 year old girl. If she in on-board I install the GGB slip-on mufflers. You would think I'm running a stock 350, but actually I'm running n/a 750's. It's amazing. If you are running a stinger dump tube, I would not run them through the mufflers. I think you could get splash back. I would stick with dry exhaust.
Attack is offline
Old 02-23-2005 | 09:44 AM
mcraymond3's Avatar
Commercial Member
Commercial Members
Attach,
Which ones are you using, the curves or bullet? I had to go to dry b/c of reversion. Will these still work?
Thanks,
mat
Old 02-23-2005 | 10:23 AM
Mcraymond, I think you can use the high flow louver inserts from ggb they have 4 1/2 and are for dry exhaust, Biggus on the board is using these with the ggb extreme mufflers and has had a significant reduction in db's around 89 db's from well over 100 db's but no loss in mph or rpm's, Jeff
Old 02-23-2005 | 05:00 PM
Attack's Avatar
Thumbs up Re: which muffler to use?
Mat,
I'm running Stelling big tubes with the stinger tip. My clamp-ons are M-4530 Extremes, and the inserts are SI-4070. I would suggest calling Gram at GGB. He will fix you up (888)-828-7268.
Attack is offline
sonic35ss
Sonic
5
05-12-2008 04:57 PM
amarek
Baja
16
03-26-2008 08:46 PM
MILD THUNDER
Northern Illinois Offshore Club
0
07-02-2007 04:27 PM
FormulaM2Formula
06-03-2006 02:25 PM
Fast Forward
Powerquest
9
05-09-2006 01:25 PM
