Merc 525 "Safe Mode" >
Old 02-25-2005 | 09:32 AM
LostinBoston's Avatar
Default Merc 525 "Safe Mode"
A couple weeks ago while running my 36 Nortech w/ 525's i couldnt get above 4000 RPM's. It went in for service, and i was told that a "Safe Mode" has been triggered. The codes were cleared, but when i went out again, the same thing happened. What could be triggering this code? Could anything else be limiting the engine RPM's?
I made sure the gear shifter was all the way foward, if its back a bit it can still be in gear but the computer may think its in N, and limit the rpms.
Any help/ideas will be great
-Rick
LostinBoston is offline
Old 02-25-2005 | 09:38 AM
Dave_N's Avatar
Default Re: Merc 525 "Safe Mode"
Are you getting an audio alarm?
Do you have a smartcraft display?
Dave
Dave_N is offline
Old 02-25-2005 | 10:38 AM
Yeah i have the smartcraft gauges but nothing from them. Im not getting an audio alarm.
Old 02-25-2005 | 11:02 AM
marinetrans's Avatar
When the PCM555 limits the motor to 80% power, it could be a sea water pressure sensor,sea water temp. sensor or coolant sensor. The PCM sees that the engine is not overheating or running w/ low oil pressure by going through a systems check. Then decides to limit power according to what it finds, anywhere from 10%-90% power available.Sounds like its seeing a sensor out of range and the other sensor aren't backing it up.
marinetrans is offline
Old 02-25-2005 | 11:08 AM
Dave_N's Avatar
marinetrans is correct, it could be one of the sensors. However, you should get an audio alarm if that were the case.
I asked about the smartcraft display thinking that you could verify the in gear/neutral status on the display. Sounds like you have had issues with that before.
Dave
Dave_N is offline
Old 02-25-2005 | 11:17 AM
Strip Poker 388's Avatar
Rob
What were the codes?
What are the gages reading when it went into safe mode ?
Strip Poker 388 is offline
Old 02-28-2005 | 05:04 PM
Plugged the computer in today and there were no codes this time. The motors have 61 hrs on them and are goin in to be tuned later this week. Hopefully that shoudl take care of everything. When i brought the tabs up all the way i got 4700 RPM's. Still not as high as they should be turning though.
Old 02-28-2005 | 08:41 PM
Fuel PSI? Your can filter could be clogged or it is to late and your pump went south.
Lee-way is offline
Old 03-01-2005 | 12:03 AM
Rob
If something is wrong I would not be trying to keep running it.If that shop cant figure it out try another.
Whats the gages reading???If there ok its got to be what marinetrans said.
Old 03-01-2005 | 05:48 AM
offthefront's Avatar
If i had 525's with 61 hours on them ....I would definately get to the bottom of it .....If you dont have complete confidence in your shop ....find another .....too much $$$$ to fug around with ....
offthefront is offline
