Head gaskets--Fel-Pro  or Cometic >
View Poll Results: Which head gskt should I use ??
Fel-Pro 17048
44
27.85%
Cometic
101
63.92%
Other brand ??
13
8.23%
Voters: 158. You may not vote on this poll
Old 04-06-2008 | 09:41 AM
  #61
I've got a set of MK IV cometics and 502 GenVI cometics brand new for $160 a set. Will post pART# IF INTERESTED
Part# on the cometics is c3 h1177spa-040s. The bore size is 4.560. will work up to a.060 overbore on a 502.
kennyo is offline
Old 04-06-2008 | 10:25 AM
  #62
post part number, i have a 4.550 bore.
and guys thanks for the help.
nas t is offline
Old 04-06-2008 | 01:16 PM
  #63
Although I like the Cometic over Fel-Pro while freshening this season the Cometic's did blow between cylinders. We are O-ringing it this year. Pro-Charged 7lbs boost.
Bob
RBeyer is offline
Old 04-06-2008 | 08:24 PM
  #64
GPM
Since I cut the timing back, I've run two seasons on the same 1077s with 15lb of boost and no problems. The Felpro's have one wide crimp between cylinders where Cometic tries to put two.
GPM is offline
Old 04-07-2008 | 08:27 AM
  #65
I'll get them tonite.
kennyo is offline
Old 04-07-2008 | 01:17 PM
  #66
kennyo is offline
Old 04-07-2008 | 01:28 PM
  #67
Strip Poker 388's Avatar
Rob
man thats a long part #
Ive never bought conetics before, I wonder how it breaks down?
Strip Poker 388 is offline
Old 04-07-2008 | 02:35 PM
  #68
WildWarrior's Avatar
We run Cometics- 14-71s with 14 to 16 lbs of boost zero problems.
Others run Cometics beyond 20lbs of boost with zero problems.
If you do have detonation what would you rather blow, your gasket or your piston?
Because if your running copper you just lost a piston or worse!
If your not detonating, 20+lbs of boost in it self should not take out your Cometic gasket!
WildWarrior is offline
Old 04-08-2008 | 10:27 AM
  #69
Cometic back ordred these on me and I went with the FelPros because I could get them locally. Machinist couldn't get his money back so I told him I would try to sell them for him. Anyway, that was the # he gave me.
kennyo is offline
Old 03-15-2009 | 11:07 AM
  #70
I thought I would revive this thread and see if anybody's
changed their minds. lets hear your opinions
Cometic or Felpro MLS ?
Gen 6 502 4.466 bore AFR heads 10psi boost.
should the MLS be sprayed with anything??
outlaw is offline
