Spiro locks... is there
A better way to get them in? I checked deck square today, cleaned painted the block and put in the cam bearings and frost plugs. I scribed the gaskets and then measured the top ring to see how far to grind. It's is all good
. I Unshrouded the valves and I then checked the Clarence on the mains .003, and then end play. Torqued it down the Mains and then got really frustrated with the Spiro locks on the pistons, so, i just mocked it up for a woody moment. I am usually not this far behind the curve on anything. I went to the JE website and read the instructions and still struggled. Is there a easier way? Has some motor guru out there that done this and got a system i was using a small right angle o ring pic and a small ignition screwdriver. any suggestions welcome.
they are entertaining
stretch them alittle, tiny screwdriver, spin them in
P.S there are 4 spirolocks per piston
learned that a few years ago.. only ran 2 locks per piston in first motor, nothing went wrong
opps
opps
opps
oppsI would like to do this the right way. I do not think that installing only one is the correct way if the Manufacturer Says put two per side. But just for entertainment purposes..... how hard did you run your last motor that u only used one per side?
Yes yes yes i have that and they are a PITA... just looking for anything helpful
Post #3 and the JE instructions from rmbuilder describe what has worked best for me. I carefully use a very small screwdriver to thread the lock into the piston groove. Like a lot of things, there's a technique to it. Ya don't want to spread the coils too far in the process of installing them. Since you don't reuse them, I've purposely abused a few removing them to see how sensitive they are, They're actually quite forgiving in my opinion. You'll probably find that you get the hang of it about the time you finnish the last piston.
