why r mer's engs making more hp that jc's @ >
Old 03-18-2005, 10:24 PM
KAAMA's Avatar
Default Re: why r mer's engs making more hp that jc's @
Originally Posted by RumRunner
Mark has worked real hard on his packages, and does a fair amount of testing. He has made mutiple changes to find what works the best. He's actually left some peak HP on the table in the name of curve, and drivability. He still has small flange carburetors on Fred's engines, going to a pair of King Demons would pick the numbers up even more. As stated before the entire package, or combination is the thing.
I agree with the concept of your statement. I am a firm believer in sacrificing some top end HP for good throttle response, and good drivability especially in a marine engine.
KAAMA is offline
Old 03-18-2005, 10:38 PM
KAAMA's Avatar
Originally Posted by Too Old
If this thread is for the sake of discussion and possibly better understanding what it takes to set up a marine motor with a nice combination of HP, torque and RPM then I"m all for it.
But if it's the "great marine motor build off", it's unfair.
Engine builders have a numerous constraints imposed by customers. Some customers have an idea of what they think they want and isnsit on parts that may not be the engine builders choice. Sometimes, used or exsisting parts a customer has may come into play. And then there's financial constraints.
I am with you on your post Fred. There are or can be a ton of variables, but personal preference, and especially how much money a person has to spend on an engine project will most certainly dictate the outcome of performance, and reliability of an engine building project for sure.
KAAMA is offline
Old 03-19-2005, 07:53 AM
KNOT-RIGHT's Avatar
Originally Posted by ratman
caveman told mark @ mer i wouldn't disclose cams specs as part of eng build. it is a solid roller with a lot of lift and duration, and as you can see on too olds motors makes an azz load of hp and torque down low. mine motors are the next project on marks @ mers to do list.
Nice.
"If you told me you would have to kill me"
I guess if I had a winning combo. I would be reluctant
to give it away also. That exsplains why Too Old
avoided my question on a old post.
Gerry
KNOT-RIGHT is offline
Old 03-19-2005, 10:35 AM
KAAMA,
RFE "Ray Franks Engineering"
RumRunner is offline
Old 03-19-2005, 09:52 PM
JCPERF's Avatar
too old i was trying to understand why your motors which i have seen at mers shop, using those huge port profiler heads would be more of a high rpm power maker. when i saw the dyno #'s from your 2nd engine and WHERE your motors made all that power amazed me. then i looked @ jc'syno sheet and his motors make hp at a lot higher rpm with smaller heads and blowers which didn't make sense to me. i know what cams your running in your motors as marks putting the same ones in mine and there is nothing mild about them yet the motors make massive hp at a really resonable rpm level which should make them last. BTW why will your baot actually have them motors in it? what is the first poker run you plan to attend this year? your ride is looking sweeter all the time. ratman
Camshafts determine alot of power in a blower motor and where its made.
JCPERF is offline
Old 03-20-2005, 06:55 PM
LubeJobs42's Avatar
Truthfully, Does it matter what HP Too Olds motors make? They are the worlds most fuel efficient motors. They will not burn one gallon of gas between them this year!!! LOL
LubeJobs42 is offline
Old 03-20-2005, 07:06 PM
JCPERF's Avatar
They will look just as pretty 3 years from now?
JCPERF is offline
Old 03-20-2005, 07:19 PM
KNOT-RIGHT's Avatar
What question was that?
More than likely I just didn't have an answer to your question. I apologize if I breezed over it as if I wasn't interested in answering.
Remember, I'm NOT an engine builder. That's why I use Mark Renda and let him do his thing.
Well from what I see in those dyno sheets his "thing"
is working!
I like to know what combos work.
I am considering the profilers for my next rebuilds.
http://www.offshoreonly.com/forums/s...&highlight=cam
I try to do as much as I can myself. Its the only way I can afford this sport.
Gerry
glassdave
OPA/The Jersey Boyz
0
09-26-2008 03:05 PM
Superbabi
Superboat
55
10-14-2005 10:55 PM
Quick Reply: why r mer's engs making more hp that jc's @
