props
Old 03-17-2005 | 07:19 PM
props
I have a 32 ft sutphen with 2 , 300 hp mercury engines that i am rigging as new. They sit on a stainless bracket. What size and type props would you recommend? The total weight should be 6200 lbs. I am looking for top speed.
jerome lusa is offline
Old 03-18-2005 | 07:09 AM
Thumbs up Re: props
Call Julie or Matt at Throttle Up 877-842-6855 they can dial you in.
Badtoon is offline
Old 03-18-2005 | 07:15 AM
BajaIceBreaker's Avatar
Default Re: props
I have a 23" Pitch Mirage, RH rotation that would probably get you started in the right direction. $200
BajaIceBreaker is offline
Old 03-19-2005 | 09:43 AM
Default Re: props
Sorry, it's a LH rotation Mirage 23" Pitch. Here's a pic. $200 buys it.
Old 03-19-2005 | 12:34 PM
two-air's Avatar
Default Re: props
Don't just buy a prop, call Throttle-Up
two-air is offline
Old 03-19-2005 | 05:09 PM
Strip Poker 388's Avatar
Rob
Default Re: props
Out board props
Strip Poker 388 is offline
Old 03-20-2005 | 08:01 AM
Default Re: props
Two-Air has a good point. You want to talk to a professional before you get started. But, once they get you started, the only way to get the exact prop for your ride is the try, try, and try again. Get the prop that's recommended, then change things a few times to tune it in perfectly.
Old 03-20-2005 | 08:04 AM
Default Re: props
If your looking for outboard props, I have a pair of Mercury Offshore Performance 4 blade props. 23" Pitch. Check the mercury description on them, they are designed for Outboard motors. They are in PERFECT condition. You can take them home for $450. Don't have a pic right now, but if you are interrested, let me know and I will get you a pic.
Old 03-21-2005 | 08:39 AM
Default Re: props
I have 2 merc Bravo 1 24 pitch props for sale
email me if you're interested and I"ll send you some pics. They are 2004 with only 10 usage
islandracer is offline
Old 03-21-2005 | 10:51 AM
throttleup's Avatar
Default Re: props
jerome lusa,
Welcome to the world of testing. In your case I have a pretty good Idea of were we need to be. But I am going to need to ask you alot of questions. Please feel free to call me.
Julie
Throttle Up Propellers
727-531-2255
throttleup is offline
mcprodesign
06-08-2008 07:54 PM
diggster69
Prop Talk
2
02-06-2008 07:59 PM
HOTTZU98
3
05-13-2005 07:43 AM
raiseyourdrive
09-15-2004 08:23 AM
dougB
0
05-06-2003 04:16 AM
