#3 - #3a
Old 03-19-2005 | 02:29 PM
bouyhunter's Avatar
Default #3 - #3a
What's the difference between #3's and #3A's?
I'm boat shopping, and have seen both. I thought I read somewhere that #3A's are stronger - why?
What about parts availilbilty on these drives?
I'm only used to dealing with TRS or Bravo, I understand whats going on in those.
Any educators out there?
bouyhunter is offline
Old 03-19-2005 | 05:23 PM
tcelano's Avatar
Default Re: #3 - #3a
IIIA's have larger shafts and are indeed tougher. The IIIA was cobbled together out of the SSM V parts bin. The parts availability on IIIA's is much better, as it is still a current production model. I have an old III, and I haven't had any trouble getting parts I needed, and many of the parts like trim pins you can upgrade to IIIA stuff if you know what you are doing. You can also bolt a IIIA drive leg up to a III bellhousing from everything I've heard, so all isn't lost if you chunk your III.
tcelano is offline
Old 03-19-2005 | 08:55 PM
Crazyhorse's Avatar
I had to have a IIIA rebuilt and Mel Riggs didn't have any trouble getting parts. It was real pricey though. But I'd expect that any SSM repair is going to be pricey.
Crazyhorse is offline
Old 03-20-2005 | 04:21 AM
bouyhunter's Avatar
Thanks guys
Old 03-20-2005 | 07:36 AM
bobbarker's Avatar
Re: #3 - #3a
I recently bought a 3a but had to send it back as my prop
didn't fit due to the larger shaft in the 3a. Finally found
a brand new 3 in the box from lake x mercury for $8500
plus shipping. Only one they had I was real lucky.
bobbarker is offline
