Do you Think This Restricted Fuel Flow
if you paid some one to due this you got riped.
that looks like teflon tape, thats a no, no, on fuel lines. the smallest littelest pece of that stuf in the carb,,, well,,, will couse you to look for a brick wall to beat your head on. you mit try mounting the pressure sender at the fuel filter out flow port, some have 2 in and 2 out and are pipe thred. or go to hyd hose repair that sells hyd j.i.c. fittings and go from JIC topipe
Bought the boat that way . I do all my on work, This is the reason why
