-   -   gimbal bearing - removal (https://www.offshoreonly.com/forums/general-q/98775-gimbal-bearing-removal.html)
Ran-Dom 32 03-21-2005 12:36 PM
Is there a trick to this? (bravo setup) my engine compartment in empty & I'm trying to pound it out from the inside - what the best way to accomplish this??
Ran-Dom 32 03-21-2005 01:16 PM
Re: gimbal bearing - removal
2 Attachment(s)
correct me if I'm wrong or do I have to disassemble further, or should the bearing clear the housing? If I pound from the inside?
Biggus 03-21-2005 01:22 PM
Yes, it will clear everything. If you are going to pound it out from the engine compartment you will ruin the seal so get one of them also. Give it a few whacks and It'll come out.
HiPerf2000 03-21-2005 01:23 PM
That should be all you have to dis-assemble. I've never beat it out from the inside....., always used the tool to yank it from the outside. Should come be same principle though. If it hasn't been changed in a while it will be tough to get out. If you can find a piece of tubing to beat it with that is the same diameter of the bearing, that would be best. and make sure you have a straight line to beat it. if you are beating it crooked it will cock and not come out.
Ran-Dom 32 03-21-2005 01:47 PM
I guess I'm not hitting it hard enough - I'll break out the sledge hammer :D
fstboater 03-21-2005 08:31 PM
Some come out easy some are very tight sledge is in order never removed one from the inside always used a 6 or 8 lb slide hammer to pull it out. Good luck
Pismo10 03-22-2005 05:39 AM
I have always used the merc alignment tool to knock it loose, works great. Just put the tool thru the hole in the bearing, wack it sideways, this will twist the bearing in the carrier and then it pulls out easily, by hand, never needed a puller. Could use any larger pipe or equivilent that will fit snug in the bearing hole.
Ted G 03-22-2005 07:36 AM
Did you remove the snap ring? I can't tell from the pic.
hillbilly24 03-22-2005 07:50 AM
there's no snap ring in there
Ran-Dom 32 03-22-2005 07:58 AM
got her done - gave her a good whack & out it came - thanks for the help.
