Re: Keith Eikert 675 Hp ???
Originally Posted by GATORONE
Jass
I think your issues were with Julie Sullivan not Keith. I will put my motors up against anyones, and the customer service that I receive from Keith is second to none. |
So Would You Purchase A Boat With This Power Or Not ?
I believe KE took the blame in a few situations where the boat was not rigged properly, i.e. coolant supply to the motor, some engine monitoring issues basically created by the boat builder. Not saying any of the above were involved but lets just say there were some situations with some noteable builders. Do you think the builder took the heat for his lack of knowledge in setting the package up?? :rolleyes:
check your pm
You here a lot of good things about KE, and his motors. These motors as well as a few on some Cigs, PP, and Velocities that year at that time had the same problems, they might have gotten them straitened out as the year went by, all I can tell you is on my own personal experiences. Jeff |
You should expect 200 hours out of these motors if you run them how? How can you tell if these motors were built by Keith himself or Julie Sullivan?
Thanks, LS JR. |
| All times are GMT -5. The time now is 09:17 AM. |
