Motor starts but does not Rev. Please help! >
Old 04-02-2005 | 02:21 PM
  #41
Default Re: Motor starts but does not Rev. Please help!
The sensor either works or won't work. No in between. I have never seen a advance module go bad. Borrow one from a local Marina. You might want to go by a complete distributor
with the module and coil in it from an auto yard. Try it and see if your problem is solved. If not thats not your problem.
Keep looking you will find it. Dont give up
1BIGJIM is offline
Old 04-03-2005 | 12:50 PM
  #42
blkhorse's Avatar
I had a camaro do exactly what your talking about,it was the ign module
blkhorse is offline
Old 04-04-2005 | 06:56 AM
  #43
Yes in cars I have replaced several. Heat is usually the cause of failure. If you take the back off of the merc one you will see its totally sealed in silicone, plus it sits out in the open, not on top of a hot intake manifold.
1BIGJIM is offline
Old 04-04-2005 | 11:38 AM
  #44
Did you adjust the valve lash/rockers yet????
If that isn't done, its not gonna run worth a chit, if at all. You might even damage the cam and/or lifters if you keep trying to start it.
Griff is offline
Old 04-04-2005 | 11:57 AM
  #45
GNJ's Avatar
GNJ
Gonna look for another distributor to try. I guy called thinks he had one but won't be back in town until tonight to verify.
Griff: There is no adjustment to the valves in this motor.
GNJ is offline
Old 04-04-2005 | 01:18 PM
  #46
bowtie's Avatar
GM doesn't use Thunderbolt V. Can't be the same as in a truck. I have the specs I just need a fax number.
bowtie is offline
Old 04-04-2005 | 02:32 PM
  #47
GNJ's Avatar
GNJ
Bowtie: The ignition is a thunderbolt IV not a V.
813-855-5397 (fax) thank you
GNJ is offline
Old 04-04-2005 | 05:10 PM
  #48
bowtie's Avatar
I emailed it to you. If you don't get it let me know and I'll fax it tomorrow. Printer is out of paper tonight.
bowtie is offline
Old 04-06-2005 | 08:51 AM
  #49
GNJ's Avatar
GNJ
Thanks Bowtie I got it and will be working on it today.
Will post results.
GNJ is offline
Old 04-12-2005 | 08:23 AM
  #50
RHC's Avatar
RHC
Well ,,, inquiring minds want to know !!!!
RHC
RHC is offline
