Bad start to the season, bad gas. >
Old 04-08-2005 | 11:24 AM
PatriYacht's Avatar
Default Re: Bad start to the season, bad gas.
That looks like the same head gasket that I use on my Gen 5 engines. On the instructions Fel-Pro said for use with Gen 5 and 6. Can be used with Mark 4 with modifications. Something about opening up some other holes. I'll try to find the instructions. Can someone else read the part number from the picture?
PatriYacht is offline
Old 04-08-2005 | 11:53 AM
Wobble's Avatar
SORE MEMBER
Looks like 17048?
Wobble is offline
Old 04-08-2005 | 12:19 PM
PatriYacht's Avatar
That's what I thought. Better check with Fel-Pro to see what needs to be done to fit Mark 4. I'm at work and I can't look for the instructions right now.
Old 04-08-2005 | 12:43 PM
Wobble's Avatar
SORE MEMBER
Patriyacht,
I would appreciate that very much. Tried to find them on the net but no luck. Engine builder is very experienced , but it don't hurt to check..
Wobble is offline
Old 04-08-2005 | 02:16 PM
mikes280's Avatar
tech # 1 800 325 8886
mikes280 is offline
Old 04-08-2005 | 02:23 PM
mikes280's Avatar
also we had gas do this two years ago but we got 3 pistons and it was rich with low timing and it did it on a 3/4 pull not wide open
mikes280 is offline
Old 04-09-2005 | 09:54 AM
Wobble's Avatar
SORE MEMBER
Mike,
I was at about 4300rpm just easing boat up to speed slowly. WOT is 56-5700rpm. Timing 36* I think that the ceramic coating on the pistons saved the others, or I would have seen more damaged pistons.
Sutphen,
Thanks for taking the time to look that up.
Wobble is offline
Old 04-11-2005 | 07:51 PM
PatriYacht's Avatar
I found the instuctions. These gaskets also fit mark4 bowtie blocks so you do have the right gaskets. On mark4 passenger and high perf. blocks, holes have to be drilled in the block on the outside between the cylinders. Bowtie blocks already have the holes. Your gaskets are positioned correctly also. The hole at the front is blocked to force coolant to the back. Sorry it was just an idea. Hope you find the reason.
Old 04-11-2005 | 08:41 PM
mikes280's Avatar
check the ring lands on the orther pistons i have seen them burn and it not show up on the top of the pistons also check the cap and rotor for cross fire or tracking in the cap and check the jets in the front of the carb make sure they are not stopped up
mikes280 is offline
Old 04-12-2005 | 05:05 AM
Linster's Avatar
Off the Radar
I would doubt that bad gas over a few months did that much damage. What kind of compression are you running? I see you posted 9.4 but these pistions look like they have at least a 16cc dome or better. From the looks of the pop ups on the pistons it looks like they are about 11-11.5/1. I see you are using steel heads as well. I would think its been detonating the whole time and it just let loose the first of the year.
Looking at the piston, notice all the black is in the quench area. Its pre ignighting before the spark. The side of the head that has the plug is the cleanest area. That look should be 180 on correct firing.
I would check the compression ratio again.
Linster is offline
