-   -   how much HP can a bravo 1 drive take? (https://www.offshoreonly.com/forums/general-q/99878-how-much-hp-can-bravo-1-drive-take.html)
tomtbone1993 04-04-2005 02:09 PM
triple application, 42ft Fountain?
Stormrider 04-04-2005 02:14 PM
Re: how much HP can a bravo 1 drive take?
What kind of power?
tomcat 04-04-2005 02:52 PM
How much power could a Bravo handle if a Bravo could handle power? :evilb: :D Whatever they tell you it's less in a big boat with four blade props. Kind of like drag racing. It's the heavy cars with the big slicks that spit out drive shafts. Would you believe no more than 500 HP? The guy to ask is SteveDavid.
Stormrider 04-04-2005 02:54 PM
Sh*t, I'm upgrading mine to an XR upper, and I have approx 550hp w/ 4000lbs weight.
RHC 04-04-2005 02:55 PM
This is a tough Question,,,, But here goes !!!! I will say that a stock Bravo 1 will handle about 400hp thats the early yrs... the later ones will take a little more about 450-475hp,,, the difference is in the weight of the boat and the drivers abilities to throttle and keep the boat in the water ( hooked up),,,,, after that we start talking about the XR series and newer tec gears and shafts,,,, with those upgrades U can run about 650 hp and get some degree of reliability... I know of some boats that are pushing the 750hp range in 10k pound boats with twins,,,,, they rebuild every yr, about 100 hrs...
I think that your 3 engine boat will be harder on the center drive than a twin will be ,, but ,,, thats just my opinion..
Now ,,, lets see what the rest of the world thinks??? :D :D
Good Luck!!
RHC
44MTI 04-04-2005 03:07 PM
750 with lake running and being conservative, should run a little over 100 if it is a steep bottom. At least this what my friend ran a few yrs ago.I don't think he ever blew a drive, again only lake running. He upped the power after 1 season and blew like 7 drives the next yr. usually the center drive and you can't get up on two .
Smitty 04-04-2005 04:02 PM
I ran 550 HP thru a Bravo for 4 seasons no problem. Got on it once in a while off the line, but I never flew the boat without cutting the power first.
38tg 04-04-2005 07:48 PM
my top gun has had twin 600sc's for 5 years, i only twisted 1 prop shaft. just don't launch it hard....
50boat 04-04-2005 09:33 PM
:eek: iam running 750s 2 years , and 2 pokers miamie to kekwest :D :D in a 42 fountain 1.5 gears torning 33 4 blades. come on plane ease to 40 mph, and hammer down :evilb:
gsmith9898 04-04-2005 09:55 PM
I'm looking at buying a 26 eliminator with the 575 and a bravo 1. Will the bravo hold up?
