Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
Anyone run a vacuum pump? >
Old 06-20-2006 | 03:26 PM
Prater's Avatar
Default Anyone run a vacuum pump?
Posted in tech, but no responses so thought I would try here...
I have some excess oil pan pressure on my engines. The cylinder leakdown and pressure tests are normal, but there is still a pressure issue at high rpm. I have ran an electrical vacuum pump on one of my race cars before and was wondering if anyone has ran them on a boat. I do not want to pull through the carbs because of the excess oil being scavenged through the breather. The carbs already need a good cleaning.
If you are running a vacuum pump please let me know how it is working for you. I can go electric again or run a crankshaft pump.
Prater is offline
Old 06-20-2006 | 03:58 PM
Default Re: Anyone run a vacuum pump?
we used to pull vacuum with drysump , any type should work just like your car however vacuum pulls oil from and tends to dryup the piston domes and as you know the oil is important to cool the pisons ( we used dome oilers and rifle drilled rods) we sealed the engine so we had to be carefull of seals etc . as long as engine is vented you should be ok
Larry D is offline
Old 06-20-2006 | 04:11 PM
We found that low tension oil rings work well with a dry sump set-up, this will help the pistons skirts live.
HighPriority is offline
Old 06-20-2006 | 04:54 PM
Prater's Avatar
Thanks,
The pressure is blowing oil all in the bilge through the breathers and the oil caps at 5lbs of boost. It may be cheaper for me to invest in newer valve covers with a better cap and baffle design.
Prater is offline
Aero654
Drives and Lower Units
5
04-09-2008 10:09 AM
CC247
5
07-09-2007 07:43 PM
nocigarette
0
04-08-2007 04:59 PM
bcarpman
4
09-17-2006 10:41 AM
Prater
10
06-25-2006 08:50 PM
